I want to get rid of hostapd, because it is very unstable, and use wpa_supplicant instead.
What I did
So I followed these instructions. I have a RasPi 1 with two external wifi dongles. I used a fresh image of raspian stretch lite (2018-11-13).
Before I did, I enabled predictable network names (I will call my interfaces wlxINET and wlxAP here to make it more readable and because of privacy concerns).
I ran following commands:
sudo -Es
apt update
apt full-upgrade
apt install rng-tools
systemctl mask networking.service
systemctl mask dhcpcd.service
mv /etc/network/interfaces /etc/network/interfaces~
sed -i '1i resolvconf=NO' /etc/resolvconf.conf
systemctl enable systemd-networkd.service
systemctl enable systemd-resolved.service
ln -sf /run/systemd/resolve/resolv.conf /etc/resolv.conf
cat > /etc/systemd/network/08-wlxINET.network <<EOF
[Match]
Name=wlxINET
[Network]
DHCP=yes
EOF
cat > /etc/systemd/network/12-wlxAP.network <<EOF
[Match]
Name=wlxAP
[Network]
Address=192.168.4.1/24
IPForward=yes
DHCPServer=yes
[DHCPServer]
DNS=84.200.69.80 84.200.70.40
EOF
cat > /etc/wpa_supplicant/wpa_supplicant-wlxAP.conf <<EOF
country=DE
update_config=1
ap_scan=2
network={
ssid="my_accespoint"
mode=2
key_mgmt=WPA-PSK
psk="my_passphrase"
frequency=2412
EOF
cat > /etc/wpa_supplicant/wpa_supplicant-wlxINET.conf <<EOF
country=DE
update_config=1
network={
ssid="accespoint"
psk="passphrase"
EOF
chmod 600 /etc/wpa_supplicant/wpa_supplicant-wlxAP.conf
chmod 600 /etc/wpa_supplicant/wpa_supplicant-wlxINET.conf
mkdir /etc/systemd/system/wpa_supplicant@wlxINET.service.d/
cat > /etc/systemd/system/wpa_supplicant@wlxINET.service.d/override.conf <<EOF
[Service]
ExecStartPre=/sbin/iptables -t nat -A POSTROUTING -o wlxINET -j MASQUERADE
ExecStopPost=-/sbin/iptables -t nat -D POSTROUTING -o wlxINET -j MASQUERADE
EOF
systemctl enable wpa_supplicant@wlxINET.service
systemctl enable wpa_supplicant@wlxAP.service
What happened
After rebooting I can see a new access point, but if I connect, it keeps reconnecting all the time (with different interfaces in different intervals: using the internal chip of my laptop, it dis-/reconnects every second, with an external dongle only every 10 seconds.)
When I run systemctl status wpa_supplicant@wlxAP.service it shows me the dis- and re-connections, but no error messages.
Using hostapd with the following configuration, I don't have this reconncetion issues. So I think that there has to be something wrong with wpa_supplicant.
interface=wlxAP
driver=nl80211
ssid=my_accespoint
channel=11
hw_mode=g
ignore_broadcast_ssid=0
wpa=2
wpa_key_mgmt=WPA-PSK
rsn_pairwise=CCMP
wpa_passphrase=my_passphrase
auth_algs=1
wpa_group_rekey=600
wpa_ptk_rekey=600
wpa_gmk_rekey=86400
country_code=DE
ieee80211d=1
macaddr_acl=0
ctrl_interface=/var/run/hostapd
ctrl_interface_group=0
wmm_enabled=0
Am I missing something, did I do something obviously wrong?
It's not that I really need to change to wpa_supplicant, but really would like to know, what is going wrong there.
EDIT:
I bought a RasPi 3 and got the same problem (using the internal wifi chip).
Now I get following error message when running systemctl status wpa_supplicant@wlan0.service
Mär 06 13:02:55 raspberrypi wpa_supplicant[529]: Failed to create interface mon.wlan0: -95 (Operation n
Mär 06 13:02:55 raspberrypi wpa_supplicant[529]: wlan0: Could not connect to kernel driver
