The append line adds extra options to the kernel command line in UNIX derivatives. You can add many extra options such as
- root device (/dev/sda2 in your example)
- initrd file
- debugging options such as 'quiet'
- hdd emaulation (ide-scsi)
- boot type (single, rescue etc.)
- VGA mode
You can find which options you can pass to append line in QEMU kernel options manual : page is now archived
Edit:
If you want to pass different root partition you can pass via root=/dev/sdXX. You should display your disk layout with fdisk command if you don't know your image's root partition. Example of a sd card image disk layout:
root@pi# fdisk -l moebius.1.0.1.img
Disk moebius.1.0.1.img: 943 MB, 943718400 bytes
255 heads, 63 sectors/track, 114 cylinders, total 1843200 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000714e9
Device Boot Start End Blocks Id System
moebius.1.0.1.img1 8192 122879 57344 c W95 FAT32 (LBA)
moebius.1.0.1.img2 122880 1761279 819200 83 Linux
As you can see linux root partition is 2nd partition, that means it will named /dev/sda2 when you try to boot via qemu-system-arm.
