I am using openhabian. I have managed to get the Pi connected to the internet via the Quectel UC20-G modem after which I get a new interface called ppp0 with IP address 49.225.37.106 as shown below.
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
    inet 127.0.0.1  netmask 255.0.0.0
    inet6 ::1  prefixlen 128  scopeid 0x10<host>
    loop  txqueuelen 1000  (Local Loopback)
    RX packets 57  bytes 4138 (4.0 KiB)
    TX packets 57  bytes 4138 (4.0 KiB)
ppp0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>  mtu 1500
    inet 49.225.37.106  netmask 255.255.255.255  destination 10.64.64.64
    ppp  txqueuelen 3  (Point-to-Point Protocol)
    RX packets 5  bytes 55 (55.0 B)
    TX packets 4  bytes 58 (58.0 B)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
    inet 10.10.10.100  netmask 255.255.255.0  broadcast 10.10.10.255
    inet6 fe80::ba27:ebff:fe95:2b41  prefixlen 64  scopeid 0x20<link>
    ether b8:27:eb:95:2b:41  txqueuelen 1000  (Ethernet)
    RX packets 2686  bytes 577086 (563.5 KiB)
    TX packets 562  bytes 102198 (99.8 KiB)
Now I'd like to connect my PC to the Pi via Ethernet port and access the internet that the Pi uses via ppp0. I did some research online and performed the below steps.
First I edited the interfaces file (/etc/network/interfaces) as shown below:
auto lo
iface lo inet loopback
iface eth0 inet static
address 10.10.10.185
gateway 49.225.188.178
allow-hotplug wlan0
iface wlan0 inet manual
iface default inet dhcp
In the above, the address is the static ip to the eth0 and gateway is the ip address of the Pi at ppp0.
After this I ran the following commands with the Ethernet of my PC connected to the Pi.
[11:24:28] openhabian@openHABianPi:~$ sudo route del default
[11:31:22] openhabian@openHABianPi:~$ sudo route add default gw 10.64.64.64 dev ppp0
[11:31:42] openhabian@openHABianPi:~$ sudo route
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
default         10.64.64.64     0.0.0.0         UG    0      0        0 ppp0
10.10.10.0      0.0.0.0         255.255.255.0   U     0      0        0 wlan0
10.64.64.64     0.0.0.0         255.255.255.255 UH    0      0        0 ppp0
link-local      0.0.0.0         255.255.0.0     U     1000   0        0 wlan0
Then ran some iptables commands as below.
[11:34:15] openhabian@openHABianPi:~$ sudo sysctl net.ipv4.ip_forward=1
net.ipv4.ip_forward = 1
[11:34:20] openhabian@openHABianPi:~$ sudo iptables -t nat -A POSTROUTING -o ppp0 -j MASQUERADE
[11:34:32] openhabian@openHABianPi:~$ sudo iptables -A FORWARD -i eth0 -o ppp0 -m state --state RELATED,ESTABLISHED -j ACCEPT
[11:34:36] openhabian@openHABianPi:~$ sudo iptables -A FORWARD -i ppp0 -o eth0 -j ACCEPT
[11:34:44] openhabian@openHABianPi:~$ sudo sh -c "iptables-save > /etc/iptables.ipv4.nat"
After doing the above, I am still not getting internet on my PC from the Pi. Can someone please guide me with this to getting this working.
Ingo
  • 42,961
  • 207
Beedee
