I'm using the Rpi 3B+ and understand the hardware uart is used by the bluetooth. I'm OK to use the other uart
I've followed several threads and believed I've done all I can.
  1. Enabled the Uart in config.ini
  2. Set the 'core_freq=250'
  3. Disabled the Console in cmdline.txt
    (I've double checked using the config tool)
This command shows the serial ports
ls -l /dev/ttyS0 /dev/ttyAMA0
.. and shows
crw-rw---- 1 root dialout 204, 64 Feb 28 14:17 /dev/ttyAMA0
crw--w---- 1 root tty       4, 64 Feb 28 14:17 /dev/ttyS0
But this python command only shows one port.
python -m serial.tools.list_ports -v
/dev/ttyAMA0
    desc: ttyAMA0
    hwid: 3f201000.serial
1 ports found
What am I missing here.. ( inexperienced user )
Rob Field
Undo everything you did and enable serial in raspi-config.
Write to /dev/serial0 (which is the default serial port).
PS I tried the python -m serial.tools.list_ports -v you listed.
It only shows 1 port, as you stated, despite my Pi being correctly configured with a serial port. The fault seems to be with the tool you used - nothing to do with the Pi.
