I am new Raspberry pi user, recently while exploring , I did a remote shutdown of my Rpi with sudo halt command, since then I am not able to connect the Rpi remotely from my windows machine using putty , when ever I try , I get Network Error: Connection timedout error. I guess I have set a Static ip address, as I have not change any configuration to enable DHCP server.
- 42,961
- 20
- 87
- 207
- 113
- 1
- 3
You wrote you do not have made any changes to enable using a DHCP server. On Raspbian this is the default setting out of the box. If you do not changed any settings on the network configuration then the RasPi will get an ip address from a DHCP server that is very often presented by the (internet) router. if a DHCP server isn't found the RasPi will use a link-local address that can be addressed with raspberrypi.local.
Seems you have found the ip address from the first boot so you could connect to it. But with a reboot it is possible that the RasPi gets a new ip address. It's now up to you to find the new ip address. Here are many answers about to find ip address. One that may help you I have found at How do I find out the IP address of my Pi?. Have also a look at the comments on that answer.
- 42,961
- 20
- 87
- 207
