I bought a $5 usb charger that I am using to power my Raspberry Pi. The charger works decently but I am noticing that every once in while the raspberry pi will reboot. I have read that some chargers that supply 5v often drop under 5volts. Does this mean I need a battery that supplies a little over 5volts? I also read that any voltage over 5 will fry the pi? Can someone explain how to properly select a battery to buy for the Raspberry Pi B?
sirshakir
  • 85
The best answer would come from the system designer, in this case the Raspberry Pi foundation. You don't say which Raspberry Pi you have. The 3 is notorious for being finicky about voltage drops, the 3b less so in my experience.
The Foundation says "The Raspberry Pi 3 is powered by a +5.1V micro USB supply. Exactly how much current (mA) the Raspberry Pi requires is dependent on what you connect to it. We have found that purchasing a 2.5A power supply from a reputable retailer will provide you with ample power to run your Raspberry Pi."
Note they said 5.1V, not 5V.
https://www.raspberrypi.org/documentation/hardware/raspberrypi/power/README.md
softweyr
