I want to start experimenting with Java on a PI, following this guide http://docs.gluonhq.com/embedded/#_setting_up_the_raspberry_pi and started with
  • PI ARMv6 rev 7 (v61)
  • Kernel Linux 4.14.79+
  • Raspian GNU/Linuxx 9 (stretch)
And tried two Java 11 versions
Untarred both to a directory in /opt/. But both give an error "Illegal argument" when trying out these commands
/opt/jdk-11/bin/java -version
/opt/zulu11.1.8/bin/java -version
Am I using wrong versions?
Frank
  • 328
Linux applications are not portable across all distributions of the same architecture and ABI. This is mainly because different distributions use different versions of libc, but there may be other, more subtle reasons. Because of this, every Linux distribution comes with an official repository you can get the compatible software from.
Also, most packages targeting Debian armhf are built with VFP3-D16 hardware support and thus won't work with software built for ARMv6 CPUs (which only have VFP2). Take a look at the java file you have installed with readelf or objdump to see what exact architecture it's built for. If you see CPU_arch: v7, FP_arch: VFPv3 or something along the lines, that won't work on an RPi.
Since both packages you have tried out are based on OpenJDK, you should be able to build them from sources.
Dmitry Grigoryev
  • 28,277
  • 54
  • 147
