i am absolutely new to pi really floundering. I've written a wpa_supplicant.conf file that looks like this:
country=NZ
update_config=1
network={
    ssid="Your new Wi-Fi"
    psk="180928502831"
    key_mgmt=key_mgmt=WPA-PSK
The unit refuses to connect to my router. I have several tablet that connect fine.
I can use Realterm to ssh in (connected via an ethernet cable).
Any ideas what i'm doing wrong?
Dirk
  • 3,749
I assume you are using Raspbian. If you followed the instruction Setting WiFi up via the command line then you only need ssid= and psk= in /etc/wpa_supplicant/wpa_supplicant.conf so just delete the line with key_mgmt=. If you really want to use it then you must use a correct statement as @Dirk also stated in his comment.
key_mgmt=key_mgmt=WPA-PSK is wrong.
You must use
key_mgmt=WPA-PSK but as said it's not needed.
If there additional problems then you should look at How do I set up networking/WiFi/static IP address?.
Ingo
  • 42,961
  • 207
