So I am working on a project where I have to be able to make sip calls to a raspberry pi 3 and have it automatically answer any incoming calls. I have been reading this guide: https://wiki.linphone.org/xwiki/wiki/public/view/Linphone/Linphone%20and%20Raspberry%20Pi/. But when trying to run the code I get this error:
  File "linphoneCall.py", line 17, in __init__
    callbacks = linphone.Factory.get().create_core_cbs()
AttributeError: 'module' object has no attribute 'Factory'
If anyone knows how to fix this issue or can recommend me a method of making sip calls through code automatically on the pi, I would appreciate it very much. Thanks
Ingo
  • 42,961
  • 207
zbell23
I just had the same project today, here is how I did it.
  1. boot the Raspberry Pi in the lastest version of Raspbian
  2. click on the raspberry icon at the top-left corner, then click "Add/Remove Software"
  3. type "linphone" in the search bar. You will see a package called "SIP softphone-graphical client". Install that package.
  4. find linphone in /usr/bin, execute it in terminal
  5. everything is set up in a nice GUI beyond this point. I tweaked the setting for a bit and was able to call my raspberry pi from my phone. Note the auto answer feature is located in "preferences"
Alex Li
