New to Raspberry pi so this may be a rookie problem. I installed Raspbian as per instructions and all seems well, including browsing, compilations etc. I am connected via wifi and ifconfig shows a valid ip address for wlan0.
ping 127.0.0.0 gives:
pi@raspberrypi:~ $ ping 127.0.0.1
PING 127.0.0.1 (127.0.0.1) 56(84) bytes of data.
64 bytes from 127.0.0.1: icmp_seq=1 ttl=64 time=0.102 ms
64 bytes from 127.0.0.1: icmp_seq=2 ttl=64 time=0.119 ms
ping google.com gives:
PING google.com(syd09s12-in-x0e.1e100.net (2404:6800:4006:803::200e)) 56 data bytes
^C
--- google.com ping statistics ---
645 packets transmitted, 0 received, 100% packet loss, time 669783ms
So clearly not working. What am I doing wrong? Same result for all external addresses - but Chromium working fine.
Here is the config output is that helps:
pi@raspberrypi:~ $ ifconfig -a
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether b8:27:eb:ec:f0:2c txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 32 bytes 2968 (2.8 KiB)
TX packets 32 bytes 2968 (2.8 KiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.0.0.32 netmask 255.255.255.0 broadcast 10.0.0.255
inet6 2001:8003:890f:c000:9a9b:2baa:67db:a48b prefixlen 64 scopeid 0x0<global>
inet6 fe80::bf92:3e2a:3ede:678 prefixlen 64 scopeid 0x20<link>
ether b8:27:eb:b9:a5:79 txqueuelen 1000 (Ethernet)
RX packets 3109 bytes 1605135 (1.5 MiB)
TX packets 3909 bytes 521901 (509.6 KiB)
