Is there a list anywhere of the keyboard shortcuts in Raspbian? There's nothing obvious in the documentation that I've found. I've established that Cmd+r opens starts 'run' and Cmd+e opens an explorer window. Are there any others?
geotheory
  • 575
Assuming that you are using LXDE, the default desktop, you are actually runnig openbox as the window manager.
grep -A 1 \<keybind /etc/xdg/openbox/rc.xml will give you the default ones.
~/.config/openbox/rc.xml contains your shortcuts if it exists.
M Noit
  • 926
The configuration file is the lxde-pi-rc.xml that contains different keybind keys. Just add one that you want in this file following the examples.
I found the lxde-pi-rc.xml but in my case it was in a different path: /etc/xdg/openbox/lxde-pi-rc.xml
I guess that in the recent versions they changed the path.
I hope it can help you.
