I am using an Raspberry Pi 3b and a 7 inch hdmi waveshare touchscreen that connects to rpi with a hdmi cable and a micro usb cable.
I want to program a push button from GPIO pins to make the screen on/off when the button is pressed.
I can turn the backlight off with vcgencmd display_power 0 command but the touch is still working and when the screen turns on again I can see that the touches that I have made is applied.
How can I turn off touch like the backlight in this screen?
MatsK
  • 2,882
  • 22
Nimda
Find out what xinput ID your touchscreen has, then disable it with
xinput set-prop $ID "Device Enabled" 0
Note: a proper standby (halting CPU/RAM, not just the screen backlight) is not possible on the Pi, at least with stock kernel/drivers.
Dmitry Grigoryev
  • 28,277
  • 54
  • 147
I'm not sure about disabling touch, but for the button press action, that's easy with gpiozero:
from gpiozero import Button
from subprocess import check_call
from signal import pause
def screen_off(btn):
    check_call(['vcgencmd', 'display_power', '0'])
    btn.when_held = screen_on  # swap actions
def screen_on(btn):
    check_call(['vcgencmd', 'display_power', '1'])
    btn.when_held = screen_off  # swap actions
shutdown_btn = Button(17, hold_time=2)
shutdown_btn.when_held = screen_off
pause()
Alternatively you could use when_pressed or when_released, or even use two combined.
See a similar example and see Button docs.
ben_nuttall
  • 2,471
