I have a Raspberry Pi 3 B+ and I'm trying to use it to run some servos. I'm brand new to the hardware and networking part of this setup - I only have experience with programming, but not this part.
I want to set up the Raspberry Pi so I can program on it using my laptop.
I'm using this guide. But I'm stuck on the part where I SSH into the Pi.
I flashed the recommended Raspian download + other software to an SD card and inserted it into the Pi. I saved the blank ssh file to the boot folder, as well as a wpa_supplicant.conf file that has this inside:
update_config=1
country=US
network={
ssid="NETWORK SSID"
psk="YOUR PASSWORD"
key_mgmt=WPA-PSK
I found the IP of the Pi by plugging it into my router and using the Fing app to see the IP was 10.10.10.110. When I try to SSH into that address using Putty, it gives me a network error and says the connection timed out.
I try to ping the Pi from my laptop and it says destination host unreachable.
Any ideas?
