I'm attempting to get a minimal buildroot system up and running on my Raspberry Pi 3 B+ but after I've flashed the SD card, installed the card, powered up the pi, and connect an HDMI cable, I only ever get the multicolor screen with the lightning bolt.
From what I understand, I should be getting a getty prompt with the ability to login. I've followed the instructions on the buildroot GitHub page: https://github.com/buildroot/buildroot/tree/master/board/raspberrypi but with no avail. I run the following commands to build the image:
make raspberrypi3_64_defconfig
make
The result of my build contains the following files/directories:
cm2710-rpi-3-b.dtb
bcm2710-rpi-cm3.dtb
boot.vfat
rootfs.ext2
rootfs.ext4
rpi-firmware
sdcard.img
zImage
I then flash the card with sudo dd bs=4M status=progress if=sdcard.img of=/dev/sdb
I don't see any options explicitly for the raspberry pi 3 b+, I just assumed the raspberrypi3_64_defconfig was the correct configuration.
Getting to a login screen will be a huge win for me! Thanks.
user985030
  • 141
raspberrypi3_64_defconfig isn't even listed in the readme, I assume because it's experimental. Try
make raspberrypi3_defconfig
That's the one listed so it should be expected to work.
T. M.
  • 869
I figured out what my issue was. For some reason, the version of build root I pulled down didn't contain the proper files for the Pi 3 B+. These are the steps that I followed:
  1. git clone https://github.com/buildroot/buildroot.git
  2. cd buildroot
  3. make raspberrypi3_defconfig
  4. make
  5. dd bs=4M status=progress if=./output/images/sdcard.img of=/dev/sdb
I then put the card in and it booted like a champ. Now I can spend time configuring my OS with what I actually need! Yay!
To be clear, the file that I couldn't find when was this one: bcm2710-rpi-3-b-plus.dtb. That was definitely the magic sauce that caused me to fail previously. Thanks @T.M. for pointing this out to me.
user985030
  • 141
