I'm remoting into a RPi Zero W using SSH. The RPi is connected to the internet via Ethernet cable. I want to set-up the WiFi at the current remote location and check that it will work when the Ethernet cable is disconnected.
I can set-up the WiFi via raspi-config or by directly editing the wpa_supplicant file. Is there a way to verify remotely that the WiFi will work once the Ethernet cable is unplugged?
If I run iwgetid I get nothing back, ostensibly because the wireless LAN is not currently being used. The command iwconfig gives me:
lo no wireless extensions.
eth0 no wireless extensions.
wlan0 IEEE 802.11 ESSID:off/any
Mode:Managed Access Point: Not-Associated
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
If I run sudo iwlist wlan0 scan I can see the network I want to connect to. Is there any way to test it while plugged into Ethernet?
OS is Raspbian installed via NOOBS v. 2.8.1. I did verify the RPi can connect to the internet over WiFi at my location before shipping it off to the current remote location.
