I have a potentiometer that is used to adjust volume level along with MCP3008 but even if I don't touch it, its values are going and coming as following.
Press Ctrl-C to quit...
Channel 0 minus 1: 546
Channel 0 minus 1: 531
Channel 0 minus 1: 557
Channel 0 minus 1: 536
Channel 0 minus 1: 537
Channel 0 minus 1: 552
Channel 0 minus 1: 556
Channel 0 minus 1: 535
Channel 0 minus 1: 545
Channel 0 minus 1: 528
Channel 0 minus 1: 555
Channel 0 minus 1: 553
But I don't want it to change when I'm not adjusting it. As a solution I make a range in which if the range difference greater than 10, do alteration. But If I do that, volume adjusting is immediately going down or up not slowly(gradually). How can I solve it? I checked that it has ground connection well.
Code:
# Simple example of reading the MCP3008 analog input channels using its
# differential mode. Will print the difference of channel 0 and 1.
# Author: Tony DiCola
# License: Public Domain
import time
# Import SPI library (for hardware SPI) and MCP3008 library.
import Adafruit_GPIO.SPI as SPI
import Adafruit_MCP3008
# Software SPI configuration:
CLK = 18
MISO = 23
MOSI = 24
CS = 25
mcp = Adafruit_MCP3008.MCP3008(clk=CLK, cs=CS, miso=MISO, mosi=MOSI)
# Hardware SPI configuration:
#SPI_PORT = 0
#SPI_DEVICE = 0
#mcp = Adafruit_MCP3008.MCP3008(spi=SPI.SpiDev(SPI_PORT, SPI_DEVICE))
print('Press Ctrl-C to quit...')
while True:
# Grab the difference between channel 0 and 1 (i.e. channel 0 minus 1).
# Note you can specify any value in 0-7 to grab other differences:
# - 0: Return channel 0 minus channel 1
# - 1: Return channel 1 minus channel 0
# - 2: Return channel 2 minus channel 3
# - 3: Return channel 3 minus channel 2
# - 4: Return channel 4 minus channel 5
# - 5: Return channel 5 minus channel 4
# - 6: Return channel 6 minus channel 7
# - 7: Return channel 7 minus channel 6
value = mcp.read_adc_difference(0)
print('Channel 0 minus 1: {0}'.format(value))
time.sleep(0.5)
