I am distributing multiple Raspberry Pi OS images, all images are almost identical, the only difference is that there is one file /usr/MyFolder/MyFile.txt which content is different for different images.
So far the steps I take for each image are following:
- Load Raspberry Pi with micro SD that has image on it.
- Edit
/usr/MyFolder/MyFile.txt - Shut down Raspberry
- Using a card reader, read an image from micro SD card on Windows PC
I want to simplify this process and just edit these files directly from Windows PC. So basically what I want to do is to access this micro SD card from my Windows PC and edit the file /usr/MyFolder/MyFile.txt. I know there are some software for Windows that allows you to view Raspberry files, but I haven't heard of one that allows you to edit them as well.
Is this possible and if yes how?
