I already tried dist-update and this post
I have a Raspberry Pi 3 B + and my operating system is "Raspbian GNU/Linux 9 (stretch)"
I am connected to it using a Lan cable and use ssh or Remmina to connect to it.
This is my wlan configuration in wpa suppliant:
update_config=1
country=DK
network={
    ssid="secret"
    psk="secret"
    key_mgmt=WPA-PSK
network={
        ssid="eduroam"
    scan_ssid=1
    proto=RSN
    pairwise=CCMP
    eap=PEAP
    identity="secret"
    password="secret"
    key_mgmt=WPA-EAP
When connected to either of the 2 Wlan (they do connect) I dont recieve internet from them. The only way I can get internet from my raspberry pi is if my laptop is connected to wifi and then through the ethernet cable connected to my Pi I get internet. EDIT:
pi@raspberrypi:~ $ route -n
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         10.42.0.1       0.0.0.0         UG    202    0        0 eth0
0.0.0.0         10.68.64.4      0.0.0.0         UG    303    0        0 wlan0
10.42.0.0       0.0.0.0         255.255.255.0   U     202    0        0 eth0
10.68.64.0      0.0.0.0         255.255.192.0   U     303    0        0 wlan0
what i found strange is that my route -n from my raspberry pi output is always the same no matter if i enable or disable the laptop wifi and reboot inbetween.
Output of iwconfig:
pi@raspberrypi:~ $ iwconfig
eth0      no wireless extensions.
lo        no wireless extensions.
wlan0     IEEE 802.11  ESSID:"eduroam"
          Mode:Managed  Frequency:5.28 GHz  Access Point: 40:E3:D6:56:67:D0
          Bit Rate=24 Mb/s   Tx-Power=31 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Power Management:on
          Link Quality=32/70  Signal level=-78 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:160  Invalid misc:0   Missed beacon:0
my laptop is connected not to eduroam but a third wireless connection not mentioned, though there is internet on all of them, so wlan0 is from the raspberrypi for sure.
pi@raspberrypi:~ $ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.42.0.253  netmask 255.255.255.0  broadcast 10.42.0.255
        inet6 fe80::4819:8dbd:df90:5a6f  prefixlen 64  scopeid 0x20<link>
        ether b8:27:eb:81:dc:b1  txqueuelen 1000  (Ethernet)
        RX packets 7722  bytes 1829686 (1.7 MiB)
        TX packets 8297  bytes 2438399 (2.3 MiB)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 33  bytes 15914 (15.5 KiB)
        TX packets 33  bytes 15914 (15.5 KiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.68.107.205  netmask 255.255.192.0  broadcast 10.68.127.255
        inet6 fe80::aa8b:b7e0:9252:a9eb  prefixlen 64  scopeid 0x20<link>
        ether b8:27:eb:d4:89:e4  txqueuelen 1000  (Ethernet)
        RX packets 118  bytes 35794 (34.9 KiB)
        TX packets 637  bytes 103843 (101.4 KiB)
pi@raspberrypi:~ $ cat /etc/network/interfaces
pi@raspberrypi:~ $ cat /etc/resolv.conf
# Generated by resolvconf
domain eduroam.local
nameserver 10.42.0.1
nameserver 208.67.222.222
nameserver 208.67.220.220
maxsieg
  • 90
Seems there is simply a problem with your default route. As shown in your question with route -n you have two default routes:
The kernel has to decide what route to use. For this it uses the Metric. The route with the lowest metric 202 comes first so it will try to connect to the internet through eth0 but it seems there is no route to the internet.
You can check if you can connect to the internet through wlan0 with:
rpi ~$ ping -I wlan0 8.8.8.8
If you receive packages then that is the route to the internet. You should just delete the wrong route:
rpi ~$ sudo ip route del default dev eth0
and configure your network not to set this route, for example not to set static routers=10.42.0.1 in /etc/dhcpcd.conf.
By the way /etc/resolv.conf shows that resolvconf sets searching
The DNS domain .local is reserved for Link-local addresses and never managed by any DNS server and as far as I know resolvconf will never set this by itself. So you should reconfigure your settings (maybe in /etc/dhcpcd.conf?) not to use this domain. If you use avahi for link-local addresses instead of a dhcp server then it will use this domain.
Ingo
  • 42,961
  • 207
