I'm a new user to Raspberry Pi and this is my first Pi project. I'm running the latest version of Raspbian.
Question:
How do I configure my Raspberry Pi 3 B+ to map one USB port to another? One port has a thumb-drive and the other would be connected to my vehicle radio.
Background:
I have a radio receiver in my pickup truck that can play mp3, mp4 content stored on a USB thumb drive when plugged into the radio. When I want to change the content it always takes me several days to remember to bring the thumb-drive in, several more to change the content, then several more to remember to take it back out. I thought putting Pi in between the radio and thumb-drive would be a cool hack.
What I've done so far:
I've permanently mounted a thumb-drive to the Pi. When I pull into the driveway, the Pi automatically connects to my home WiFi and shows up on my PC as a mapped drive.
  • I can manually drag and drop content to it or..
  • My NAS automatically backs up from a share to the USB drive on the Pi. I can sit at my computer in the evening, drop content into the share and overnight the NAS synchs the Share's content with what's on the Pi's thumb-drive.
  • Transfer rate is 8-10 MB/sec which is plenty fast enough for me.
Thanks!
Pi 1826
You can't.
Devices which have USB passthrough are slave devices -- keyboards, cases, etc. The Pi 3 cannot be used as a slave device. I'll repeat myself from here:
USB is not a symmetrical protocol, meaning the two parties in a relationship are not equals. One is the master, and one is the slave. This is controlled in hardware, and although I believe it would be pretty simple to make a standard USB A port serve either role, conventionally they do not, I presume to prevent accidents, since plugging a master into a master can cause physical damage to one or both machines -- which is why you should never plug an A port into another A port (male-to-male cables for which are in fact hard to find).
If your car stereo has a standard USB A jack that you can plug a thumb drive into, that port is a master. So are the ones on the Pi 3, end-of-story.
As per the quote, this is the exact same reason you cannot connect your laptop to your desktop using a USB cable for data exchange.
You could use a Pi Zero, which has OTG functionality (see the link above), to emulate a thumb drive, as jsotola suggests.
