I've downloaded Raspbian wheezy from the Raspberry Pi downloads page and following the RPi Easy SD Card Setup wiki page.
I formatted the SD card, and cded into the folder containing the Raspbian img file, but when I run sudo dd if=2013-07-26-wheezy-raspbian.img of=/dev/disk2s1 bs=1m, this is the output I get:
dd: /dev/disk2s1: Resource busy
I tried it again with /dev/disk2 as the output file, but get the same error. I'm not sure what I'm doing wrong/why the img isn't being copied over.
This is the (relevant) output of $ diskutil list:
/dev/disk2
#: TYPE NAME SIZE IDENTIFIER
0: FDisk_partition_scheme *32.5 GB disk2
1: Windows_FAT_32 YQFORKLIFT 32.5 GB disk2s1
As well as $ df -h:
ysim:~$ df -h
Filesystem Size Used Avail Capacity Mounted on
/dev/disk2s1 30Gi 1.7Mi 30Gi 1% /Volumes/YQFORKLIFT
And this is what I see under System Profiler -> Card Reader:
Built in SD Card Reader:
Vendor ID: 0x05ac
Product ID: 0x8403
Revision: 1.00
Serial Number: 000000009833
SDHC Card:
Capacity: 32.48 GB (32,479,641,600 bytes)
Removable Media: Yes
BSD Name: disk2
Partition Map Type: MBR (Master Boot Record)
S.M.A.R.T. status: Not Supported
Volumes:
YQFORKLIFT:
Available: 32.47 GB (32,465,321,984 bytes)
Capacity: 32.48 GB (32,475,447,296 bytes)
Writable: Yes
File System: MS-DOS FAT32
BSD Name: disk2s1
Mount Point: /Volumes/YQFORKLIFT
