Fairly new to Linux. Trying to run Docker on a raspberrypi.
sudo service docker status
docker.service: Job docker.service/start failed with result 'dependency'.
sudo systemctl list-dependencies docker
container.d not started
sudo systemctl start containerd.service
● containerd.service - containerd container runtime
Loaded: loaded (/lib/systemd/system/containerd.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2018-12-05 11:34:57 PST; 1min 30s ago
Docs: https://containerd.io
Process: 28488 ExecStartPre=/sbin/modprobe overlay (code=exited, status=1/FAILURE)
CPU: 8ms
Dec 05 11:34:57 raspberrypi systemd[1]: Starting containerd container runtime...
Dec 05 11:34:57 raspberrypi modprobe[28488]: modprobe: ERROR: ../libkmod/libkmod.c:586 kmod_search_moddep() could not open moddep file '/lib/
modules/4.9.80-v7+/modules.dep.bin'
Dec 05 11:34:57 raspberrypi modprobe[28488]: modprobe: FATAL: Module overlay not found in directory /lib/modules/4.9.80-v7+
Dec 05 11:34:57 raspberrypi systemd[1]: containerd.service: Control process exited, code=exited status=1
Dec 05 11:34:57 raspberrypi systemd[1]: Failed to start containerd container runtime.
Dec 05 11:34:57 raspberrypi systemd[1]: containerd.service: Unit entered failed state.
Dec 05 11:34:57 raspberrypi systemd[1]: containerd.service: Failed with result 'exit-code'.
ls /lib/modules/*/modules.dep.bin
/lib/modules/4.14.79+/modules.dep.bin
/lib/modules/4.14.79-v7+/modules.dep.bin
So it looks like I have a different version of modules.dep.bin than what it wants? I'm not sure what I do next. How do I fix this? Do I need to update modules.dep.bin?
Docker was installed with:
curl -sSL https://get.docker.com | sh
Docker version:
docker -v
Docker version 18.09.0, build 4d60db4
uname -r:
uname -r
4.9.80-v7+
