i am trying to modify the dhcpcd.conf on my raspberry to remove the part where the static ip address is, however, after editing and saving the file using
sudo nano /etc/dhcpcd.conf
the changes does not take effect and after i reboot the pi, the original content of dhcpcd.conf with static ip address is back, not the one after i modified it.
here is the dhcpcd.conf looks like before modifying (please check the last part of the file where the interface eth0 starts)
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU.
# Some interface drivers reset when changing the MTU so disabled by default.
#option interface_mtu
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
# A hook script is provided to lookup the hostname if not set by the DHCP
# server, but it should not be run by default.
nohook lookup-hostname
interface eth0
static ip_address=169.254.241.99
static routers=192.168.0.1
static domain_name_servers=190.160.0.15 200.83.1.5 190.160.0.13
I want to remove or comment this part
interface eth0
but after modifying and saving the file, the changes does not take effect and after rebooting the raspberry the original dhcpcd.conf remains the same with the static ip address part.
interface eth0
Am I missing something? I have been searching online for several hours for solution but nothing works. Please let me know if you need additional info.
