I've written some python code that should start and stop another python script (Datalogger) when a button is pressed. So when the Pi is booted up I'm wanting the button script to run and then once I press the button it will start another python script. Then when I press the button again it will stop the other script from running and exit safely. Then if I press it again I want the other script to start up again etc.
My datalogger script creates a CSV file and then continuously writes data to it as long as it receives a square wave signal at the input pin. When the button is pushed it starts this script and when it is pushed again it is supposed to stop it cleanly (so the CSV is saved after the last write). However when I press the button it allows the other script to create the CSV but when I press it again it doesn't seem to stop the script (the CSV isn't populated with data) and it creates a brand new CSV (also empty when pushed again etc). Does anyone know what the problem could be? And do I possibly need to change/add some code to the script that I want to run when the button is pushed? The code for the button and datalogger scripts are shown below. Thanks.
Button script:
import RPi.GPIO as GPIO
import time
import subprocess, os
import signal
GPIO.setmode(GPIO.BOARD)
GPIO.setwarnings(False)
GPIO_switch = 24 # select pin to connect button
GPIO.setup(GPIO_switch, GPIO.IN, pull_up_down=GPIO.PUD_UP)
try:
    run = 0
    while True:
        if GPIO.input(GPIO_switch)==0 and run == 0:
            rpistr = "python3 /home/pi/Documents/DataloggerV2.py"
            p=subprocess.Popen(rpistr, shell=True, preexec_fn=os.setsid)
            run=1
            while GPIO.input(GPIO_switch)==0:
                time.sleep(0.01)
        if GPIO.input(GPIO_switch)==0 and run == 1:
            run = 0
            os.killpg(p.pid, signal.SIGTERM)
                time.sleep(0.01)
except KeyboardInterrupt:
    GPIO.cleanup()
Datalogger Script:
import datetime
from datetime import timedelta, datetime
import time
from time import sleep
import csv
from csv import writer
import signal
datestring = datetime.strftime(datetime.now(), '%Y_%m_%d-%H_%M_%S')
def my_callback(channel):
     data_writer.writerow([GPIO.input(26), datetime.now()])      # writes the detected
     # edge event to a CSV file with columns of rise/fall and the date & time of detection
if __name__ == '__main__':
    GPIO.setmode(GPIO.BOARD)       # set up GPIO numbering (BOARD = physical pins on Pi)
    GPIO.setup(26, GPIO.IN)         # set physical pin 26 as input
# create CSV file to write edge detection data to called Datalogger, with data on new line
    with open('/media/pi/KINGSTON/Datalogger_' + datestring + '.csv', 'w', newline='') as Datalogger:
        data_writer = writer(Datalogger)
        data_writer.writerow(["Edge type (0 = Falling)", "Date & Time"])       # create headers in CSV file
        GPIO.add_event_detect(26, GPIO.BOTH, callback=my_callback, bouncetime=20)     # edge detection function
        # detects both rise and fall in signal on pin 26, then runs my callback
        signal.pause()
        while True:
# main program loop here - loops detection of edges then runs my callback
          time.sleep(0.01)
I solved this by putting
     print("Program stopped")
     exit(0)
at the end of my Data logger script, after signal.pause() and before the while True: statement.
