I am trying to set up a Raspberry Pi Zero with Raspbian Stretch headlessly.
From my understanding, in order to accomplish this task requires three steps:
  1. Flash Raspbian to a microSD (I did so using Etcher).
  2. Add an empty ssh file in the boot directory.
  3. Add a wpa_supplicant.conf file with my network information in the boot directory.
The problem is, for some reason, both of the aforementioned files disappear after I try to boot up the Pi.
This is the process I use to create the files:
  1. I create the files on the microSD card using sudo (for me the directory is in /media/MyMachine/boot).
  2. Ensure that both files are inside the boot directory (even cat them to see all the right changes have been made).
  3. Stick the card in the Pi.
  4. When I cannot find the Pi on my network, I check the card and find that neither the ssh file nor the wpa_supplicant.conf file are in the boot directory.
EDIT: I should note that I am using Ubuntu on the machine I use to write onto the microSD card--the Pi contains Raspbian as noted above.
user8951490
  • 215
ssh will be deleted and wpa_supplicant will be moved. That's why they vanished.
Looks like your wpa_supplicant is not configured correctly and therefore you don't get any WLAN connectivity. Please see Prepare SD card for Wifi on Headless Pi.
framp
  • 896
to the boot directory
That depends on your perspective. If you are referring to a context on a running Pi, then the /boot directory should work.
However...there's probably no reason you would want to do this if that were the case.
If this isn't a running system, "the boot directory" is really a misnomer. This refers to the boot partition which, on a running system, is usually mounted on the /boot directory.
If the system is not running, the /boot direcory (which is on the second partition) is not the same thing as the boot partition, which is the first partition and where you want to leave those files.
So, if you've mounted the SD card, you've either mounted the first, the second, or both partitions. If the partition you are looking at has a /boot directory, that's the wrong place. It will not end up on the boot partition and will be hidden underneath the mount point on a running system.
Happened to me too. It seems to be due to a misconfigured wpa_supplicant.conf file.
Using the following file fixed it for me:
country=GB
update_config=1
network={
    ssid="my-ssid"
    scan_ssid=1
    psk="my-password"
    key_mgmt=WPA-PSK
It seems to be some kind of adolescent prank to remove files behind the back of a developer...
Pieterjan
  • 101
