I have been trying set up USB modem on my pi (Raspberry Pi 3 Model B+) but have not been successful. The modem in itself is recognized - lsusb shows the entry for the device - but I cant't get it connected to the Internet. I have a SIM card with a valid contract in the modem so that is not the problem. I would appreciate any help or advice on this.
I loosely followed this article, which ends with successfully using the exact same modem. But it didn't quite work out for me.
https://www.niandc.co.jp/sol/tech/date20151005_512.php
1. Checking USB device mode
First, My modem is probably in the modem mode, not the storage device mode. The id is the same 1004:6326 shown in the article.
2. modprobe command
Next is modprobe command. At first, /dev/tty does not have ttyUSB* files, but after running 'sudo modprobe' command, the following 4 files were created in /dev/.
crw-rw---- 1 root dialout 188,  0 Oct 10 07:07 /dev/ttyUSB0
crw-rw---- 1 root dialout 188,  1 Oct 10 07:03 /dev/ttyUSB1
crw-rw---- 1 root dialout 188,  2 Oct 10 07:03 /dev/ttyUSB2
crw-rw---- 1 root dialout 188,  3 Oct 10 07:03 /dev/ttyUSB3
This step looks the same with the article above and is probably working fine. Also this behavior is consistent; every time I boot the rpi there are no /dev/ttyUSB* files and executing the modprobe command always creates four ttyUSB files above.
3. cu and wvdial
Next I tried two things but neither worked.
3-a. cu command
In the article, 'cu' command is used to confirm the connection so I tried it. I couldn't find which ttyUSB file maps to the modem, so I ran cu on all 4 ttyUSB? files.
cu command on different /dev/ttyUSB? files produces different results;
sudo cu -l ttyUSB0
→ Says 'Line in use and ttyUSB2'
sudo cu -l ttyUSB1
sudo cu -l ttyUSB3
→ Both print 'Connected.' and freeze
sudo cu -l ttyUSB2
→ Prints error messages below:
cu: Stale lock /var/lock/LCK..ttyUSB2 held by process 6807 created 2018-10-11 13:20:14
cu: remove (/var/lock/LCK..ttyUSB2): Operation not permitted
cu: /dev/ttyUSB2: Line in use
3-b. wvdial
sudo wvdial on /dev/ttyUSB0 to /dev/ttyUSB3 all results in '--> Modem not responding.'
Update (Oct. 21, 2018)
As I stated in the comment, I should have checked the compatibility more thoroughly. Maybe there is not point anymore but here is lsusb and wvdial.conf
lsusb
'Device 005' is the USB modem
Bus 001 Device 005: ID 1004:6327 LG Electronics, Inc.
Bus 001 Device 004: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
wvdial.conf
[Dialer Defaults]
    Modem = /dev/ttyUSB3
    ISDN = 0
    Modem Type = Analog Modem
    Baud = 460800
    Init1 = ATX3
    Init2 = AT&F Q0 V1 E0 S0=0 &C1 &D2 +FCLASS=0
    Init3 = at+cgdcont=1,"IP","i-aeonmobile.com"
    Phone = *99#
    Dial Attempts = 5
    Stupid Mode = on
    Dial Command = ATDT
    Idle Seconds = 7200
    Ask Passwords = 0
    Password = "0000"
    Username = "user"
    Carrier Check = on
    New PPPD = 1
    Auto DNS = on
I finally managed to get the modem working.(Yes the modem and the SIM card turned out to be compatible; I confirmed it on Windows using the vendor's driver)
I've got two things to report.
1. Device file
I didn't notice this at first but found that running 'modprobe usbserial' creates a symbolic link as well as 4 ttyUSB* files (ttyUSB0 to 3) under /dev.
lrwxrwxrwx  1 root root           7 Nov  1 08:21 gsmmodem -> ttyUSB2
So this means ttyUSB2 is likely the modem if I have only one modem on the pi's USB ports.
2. wvdial.conf
wvdial worked after I edited two parts of it. One is to change the value of Modem to /dev/gsmodem I found above. The other is Init1 to Init4 lines. These strings are sent to the modem to initialize it when wvdial command is executed. As such, it could be that this is specific to the modem and perhaps also the region/country where the modem is used (I live in Japan). Either way, after changing these two parts, wvdial.conf looks like this and it works.
[Dialer Defaults]
    Modem = /dev/gsmmodem
    ISDN = 0
    Baud = 460800
    Init1 = ATH
    Init2 = AT+CFUN=1
    Init3 = ATQ0 V1 E1 S0=0 &C1 &D2 +FClASS=0
    Init4 = at+cgdcont=1,"IP","n-aeonmobile.com"
    Phone = *99***1#
    Dial Attempts = 5
    Stupid Mode = on
    Dial Command = ATDT
    Idle Seconds = 7200
    Ask Passwords = 0
    Password = "0000"
    Username = "user@n-aeonmobile.com"
    Carrier Check = on
    New PPPD = 1
    Auto DNS = on
