Reading this answer I get the impression both the Raspberry Pi BIOS and firmware are located on the SD card.
Is that correct? What is exactly located on the SD card? There's nothing stored on the Pi itself? Is that the reason for it not being able to boot without an SD card?
That Brazilian Guy
  • 442
Short answer: firmware is programmed into the chips on the Raspberry Pi, and there really is no BIOS.
Expanded answer from here:
The firmware is closed-source proprietary code programmed into the SoC (System on a Chip) processor, which cannot be modified. Upon power-up the firmware will initiate a bootloader on the SD card. I do not believe that any other services are provided through the SoC firmware, so it is not really a "BIOS" (Basic Input/Output System) per se. After this point everything else comes from the SD card.
According to the software section of the wiki, the boot order is as follows:
  1. First stage bootloader - This is used to mount the FAT32 boot partition on the SD card so that the second stage bootloader can be accessed. It is programmed into the SoC itself during manufacture of the RPi and cannot be reprogrammed by a user.
  2. Second stage bootloader (bootcode.bin) - This is used to retrieve the GPU firmware from the SD card, program the firmware, then start the GPU.
  3. GPU firmware (start.elf) - Once loaded, this allows the GPU to start up the CPU. An additional file, fixup.dat, is used to configure the SDRAM partition between the GPU and the CPU. At this point, the CPU is release from reset and execution is transferred over.
  4. User code - This can be one of any number of binaries. By default, it is the Linux kernel (usually named kernel.img), but it can also be another bootloader (e.g. U-Boot), or a bare-bones application.
syb0rg
  • 8,178
  • 38
