I have had my pi3 for a while now all of a sudden I start to get
IPv6: ADDRCONF (NETDEV_UP): wlan0: link is not ready IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
and stalls there until I restart the system. Sometimes it works sometimes it doesn't.
What could be the problem? What should I be looking at for the fault?
UPDATE
My dmesg
> 6.182631] brcmfmac: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f [ 6.198918]
> brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15
> Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc
> Data: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation:
> 2017-10-23 03:47:14 [ 6.349557] brcmfmac: power management
> disabled [ 8.673118] sda: sda1 sda2 [ 8.684376] sd 0:0:0:0:
> [sda] Attached SCSI disk [ 9.197354] EXT4-fs (sda2): recovery
> complete [ 9.206534] EXT4-fs (sda2): mounted filesystem with
> ordered data mode. Opts: (null) [ 13.924815] smsc95xx 1-1.1:1.0
> eth0: hardware isn't capable of remote wakeup [ 13.936968] IPv6:
> ADDRCONF(NETDEV_UP): eth0: link is not ready [ 14.000865] IPv6:
> ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 14.011252] brcmfmac:
> power management disabled [ 14.370071] NFSD: starting 90-second
> grace period (net ffffff8d64286680) [ 14.792240] IPv6:
> ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [ 23.164632]
> cgroup: new mount options do not match the existing superblock, will
> be ignored [ 24.871204] Adding 194768k swap on 4. Priority:-1
> extents:2 across:243920k FS [ 25.155197] Adding 154276k swap on 1.
> Priority:-2 extents:10 across:368636k FS [ 38.657491] bridge:
> filtering via arp/ip/ip6tables is no longer available by default.
> Update your scripts to load br_netfilter if you need this. [
> 38.677629] Bridge firewalling registered
