I want to make Sync a folder in windows to raspberry pi, which is connected via ethernet cable. I could write a program in windows to perform this operation and it executes well. But I dont want to run any program in the windows machine to push data to raspberry pi, rather I would like to write a program in Pi, to pull data from windows. I know there are several tools for this task, like rsync, samba, cifs, etc. But all those tools are built on top of SSH I assume. I tried to work with all the mentioned tools, none of them works.
While trying to debug the whole thing, I came to know that Pi, is hanging while trying to connect to the windows machine via SSH. When I try this 'sudo ssh -vvv computername@ipaddress' this is the output
OpenSSH_7.4p1 Raspbian-10+deb9u1, OpenSSL 1.0.2l  25 May 2017
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug2: resolving "169.254.71.106" port 22
debug2: ssh_connect_direct: needpriv 0
debug1: Connecting to 169.254.71.106 [169.254.71.106] port 22.
debug1: connect to address 169.254.71.106 port 22: Connection timed out
ssh: connect to host 169.254.71.106 port 22: Connection timed out
Even Telnet doesnt work. When I execute 'sudo telnet ipaddress 22', this is the output.
trying <ipaddress> ...
Just Ping works. So, whats the problem here with ssh in this case? I disabled firewalls and enabled network sharing in windows as well. I made sure ssh-client and ssh-server and installed and running on windows as well. Is there a way to sync windows folder with raspberry pi, without using ssh?
The problem is that Windows doesn't automatically host an SSH or Telnet server. You will have to set one up on the Windows machine.
evildemonic
  • 246
