I am attempting to run a scheduled .py file every 5 minutes with crontab but I don't think it's working.
I'm following this post with the instructions: Can't run python script from cron
I opened up terminal and ran crontab -e, adding in:
5 * * * * /usr/bin/python /home/pi/Desktop/BacTest/test3.py
to the crontab file.
I then saved the crontab with Ctrl-X, then Y, then ENTER.
Nothing appears to happen, even after a reboot... There is a SQLite database file that the test3.py file is supposed to update, but I don't see the updates happening. At least when I right click on the .py file and .db to view the properties there isn't any change to the last access/modification/permission change, or size of the SQLite .db file. However, if I open up terminal in the /home/pi/Desktop/BacTest and run the test3.py file it all works fine...
Any tips are greatly appreciated!
EDIT This is the test3.py file where I am using a python package called BAC0 to access a building automation system. Its really pretty simple where I can retrieve 2 data points (gas usage & outdoor temp) from the hot water system and save to SQLite on pi. BAC0 has a .save() that defaults to SQLite. In terminal on pi when I run the test3.py file it works just fine...
import BAC0
import pandas as pd
bacnet = BAC0.connect(ip='10.30.4.104/16')
hws = BAC0.device('100:99', 30099, bacnet, poll=0)
hws['THERM'].poll()
hws['OA-T'].poll()
print(hws['OA-T'], hws['THERM'])
hws.save()
bbartling
  • 237
Using:
crontab -e
This works for me:
0 4 * * * sudo /sbin/shutdown -r now    # Reboot everynight at 0400
00,30 06-23 * * * sudo /home/pi/python/scripts/router/DD-WRT_UpgradeCheck.py
Magwich
  • 116
It is possible that the problem lies in the way to call the editor.
If what you want to change is the crontab root, you must edit it with
sudo crontab -e
and with:
crontab -e
the user's
Ghanima
  • 15,958
  • 65
quito127
  • 79
