My usb wifi adapter is not working on my raspberry pi zero. PS: Im new to Linux.
The adapter is called "Realtek RLT8192EU 802.11n Network Adapter". The adapter works fine on windows 10 but not on Linux. According to the manual I have to install the drivers for it to work on linux. I tried this but I got some errors ->
Authentication requested [root] for make driver:
make ARCH=armv6l CROSS_COMPILE= -C /lib/modules/4.14.69+/build M=/home/pi/Downloads/wifi_driver/Driver/linux/driver/rtl8821AU_linux_v4.3.14_134 55.20150212_BTCOEX20150128-51
modules make[1]: *** /lib/modules/4.14.69+/build: Ingen slik fil eller filkatalog.
Stop.
Makefile:1551: recipe for target 'modules' failed
make: *** [modules] Error 2
Compile make driver error: 2
Please check error Mesg
When I type "Mesg" this is the result:
is y
Here is the output when I type "lsusb":
    Edit: Bus 001 Device 006: ID 0bda:818b Realtek Semiconductor Corp.
    Bus 001 Device 007: ID 0bda:8153 Realtek Semiconductor Corp.
    Bus 001 Device 005: ID 0bda:5411 Realtek Semiconductor Corp.
    Bus 001 Device 004: ID 1532:0037 Razer USA, Ltd
    Bus 001 Device 003: ID 045e:07f8 Microsoft Corp. Wired Keyboard 600 (model 1576)
    Bus 001 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
Here is the output when I type "uname -a":
Linux raspberrypi 4.14.69+ #1141 Mon Sep 10 15:13:50 BST 2018 armv6l GNU/Linux
Here are the drivers I tried to install but that didn't work: Drivers (kjell.com). This is the website where I bought the usb adapter from aswell.
EDIT: I read somewhere that using a powered usb-hub could solve the problem. Considering my current usb-hub is kinda low-quality (cheap), would it be a good idea to buy a new one?
Jonas
Here is how I got it working:
EDIT: I re-installed raspbian stretch. I skipped the updates and I am currently using 4.14.50+.
First I followed this tutorial: https://askubuntu.com/a/863433
But when I tried to run the "make" command I got an error:
make[1]: Entering directory `/usr/src/linux-rpi-3.6.y'
Makefile:564: /usr/src/linux-rpi-3.6.y/arch/armv6l/Makefile: No such file or directory
Executing these commands magically fixed that for me:
cd /usr/src/linux-rpi-3.6.y/arch/
sudo ln -s arm armv6l
When I tried to run the modprobe command I also got an error that my module was not found. I just had to reboot and now it finally works (I did not use the modprobe command).
Jonas
