I want to setup multiple network for wifi. One for my home and another for my office. I took the reference from stackoverflow but it did not work in mine. It works if i use the ethernet but not when using wifi dongle. Here how i setup for multiple wifi
/etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
    wpa-conf  /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
/etc/wpa_supplement/wpa_supplement.conf
update_config=1
network={
        scan_ssid=1
        ssid="MiRouter"
        psk="4444333221"
        id_str="home"
        priority=1
        key_mgmt=WPA-PSK
network={
        ssid="companyssid"
        psk="password"
        id_str="office"
        priority=2
I am using raspberry pi 2 and OS is raspbian stretch. What have i missed here?
Before the configuration was following and it was working
auto lo
iface eth0 inet dhcp
allow-hotplug wlan0
auto wlan0
iface wlan0 inet dhcp
wpa-scan-ssid 1
   wpa-ap-scan 1
   wpa-key-mgmt WPA-PSK
   wpa-proto RSN WPA
   wpa-pairwise CCMP TKIP
   wpa-group CCMP TKIP
        wpa-ssid "MiRouter"
        wpa-psk "4444333221"
iface default inet dhcp
milan
  • 135
If you are using Stretch you SHOULD NOT modify /etc/network/interfaces (indeed you can just delete it).
Your wpa_supplicant looks OK, although it contains un-necessary lines.
You should set Wi-Fi country e.g country=AU - not sure if absolutely necessary for Pi2, but still should be set.
See How to set up networking/WiFi which shows the correct contents of the files.
