I've been googling at this all night and have found multiple conflicting methods of recovering/formatting/saving corrupt SD cards but i'm a complete n00b with both Raspberry Pi and Linux.
Basically my son was playing games in retropie and accidentally yanked out the power cable and corrupted the SD card. I don't mind replacing the SD card, i don't mind reinstalling retropie and setting the whole thing up again. The only thing that is annoying me is that i've spent quite a few months playing FFVII with my daughter and we're on disk 3 trying to 100% everything as i did once upon a time. I'd very much like to retrieve the SRM save file so we can continue. Yes should have backed up etc. I know....
My understanding so far is that the best way to attempt this is from terminal commands in Linux so i've created a bootable Linux USB and i can run this on my Macbook (it has an SD card slot, my PC does not). I'll try and type up as much of what i've done so far to help outline where i am with this.
When i put the SD card in, nothing happens (when i put in a known good SD card, it pops up on the desktop right away). I know mine is corrupt and i don't expect it to work as the known good one does but i'm hoping that somehow there is a way to get a single file off it if possible.
When i run sudo fdisk -l with the known good card in, it shows up as /dev/sdc (/sda is my internal SSD, /sdb is my memory stick with ubuntu) so i'm assuming the bad card with be sdc also.
I've seen people on forums tell people to use dmesg to look for something but i'm not sure what i'm supposed to be looking for and they weren't clear. Is this relevant:
[    8.001985] scsi 0:0:0:0: Direct-Access     APPLE    SD Card Reader   3.00 PQ: 0 ANSI: 6
[    8.002209] sd 0:0:0:0: Attached scsi generic sg1 type 0
[    8.128452] scsi 2:0:0:0: Direct-Access     TDK LoR  TF10             1.00 PQ: 0 ANSI: 2
[    8.128696] sd 2:0:0:0: Attached scsi generic sg2 type 0
[    8.128892] sd 2:0:0:0: [sdc] 15669248 512-byte logical blocks: (8.02 GB/7.47 GiB)
[    8.129087] sd 2:0:0:0: [sdc] Write Protect is off
[    8.129089] sd 2:0:0:0: [sdc] Mode Sense: 03 00 00 00
[    8.129288] sd 2:0:0:0: [sdc] No Caching mode page found
[    8.129290] sd 2:0:0:0: [sdc] Assuming drive cache: write through
[    8.131211]  sdc: sdc1 sdc2
[    8.132065] sd 2:0:0:0: [sdc] Attached SCSI removable disk
Can somebody please guide me on what to do next in my attempt to read data from the SD card? How to first test if it is even possible then what to do next etc. I'd greatly appreciate it!
Crickentine
We should try to do typical disaster recovery. This isn't an easy task but I started this answer with suggestions that I think it is best to start with. With your comments we will improve the answer step by step hopefully to a solution.
You are on Ubuntu. That's good. And as you show from the kernel messages (dmesg) the kernel knows the SD Card as device /dev/sdc. That's also very good. First we will make a working image and don't touch the SD Card after this anymore. So we can work on the image with try an error and if we destroy it we can start from the beginning.
To take a working image we use dd. There is also a rescue version of dd for forensic tasks but first we use the normal one. That will give us an idea how corrupt the SD Card is. Execute this command with the SD Card inserted:
ubuntu ~$ sudo dd if=/dev/sdc of=rescue.img
ubuntu ~$ sudo chown user:user rescue.img  #take the user name you are logged in
This can take a long time depending on the capacity of your SD Card and its read performance. Times of 10 minutes or longer are possible. When it has finished with an error message about reaching the end of the SD Card pull it out and take it away. Then we archive the image so we have it by hand if we corrupt our working copy.
ubuntu ~$ gzip --keep rescue.img
This will create a compressed copy that you can restore with gzip --keep --decompress rescue.img.gz. Now you can try to mount the partitions in the image. I'm not familiar with Retropie so I don't know what partitions it has. For example I will use Raspbian Stretch Lite 2018-06-27. Look what partitions in the image with:
ubuntu ~$ sudo parted rescue.img unit s print
Model:  (file)
Disk /home/ingo/rescue.img: 3637248s
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number  Start   End       Size      Type     File system  Flags
 1      8192s   96663s    88472s    primary  fat32        lba
 2      98304s  3637247s  3538944s  primary  ext4
ubuntu ~$
Here we see what partitions exist. Now we will mount them. For this we need the Start and Size:
ubuntu ~$ mkdir sdc1/
ubuntu ~$ mkdir sdc2/
ubuntu ~$ sudo mount -o loop,offset=$((8192*512)),sizelimit=$((88472*512)) rescue.img sdc1/
ubuntu ~$ sudo mount -o loop,offset=$((98304*512)),sizelimit=$((3538944*512)) rescue.img sdc2/
You should find the right numbers from the example. If this works you can access the file systems on the image and search for your file for example:
ubuntu ~$ sudo ls sdc1/
ubuntu ~$ sudo cp sdc2/home/pi/myfile.srm . #last character is a dot
Ingo
  • 42,961
  • 207
