I need to reinstall my raspberry; I have a problem with bind missing libraries, and I have failed to solve the issue.
But the raspberry is in use, tallying power and water usage, so I would hate the downtime; it takes ages to reinstall.
Is it possible on a linux or windows to have a virtual raspberry to build an image with the extra software and configuration, so I only have to "burn" a new sd-card and swap into the machine?
Lenne
  • 233
The Raspberry Pi foundation doesn't use buildroot. It uses a set of bash scripts and qemu-user. qemu-system started seriously considering Raspberry Pi support in 2016. Guides written before this date do not emulate the Raspberry Pi, but a superficially similiar "Versatile PB" board. It works ... i guess.
You have three options.
  • Modify the foundation buildsystem. It already works. Obviously Linux-only: https://github.com/RPi-distro/pi-gen
  • Play around with a version of QEMU newer than 2.6 , which emulate the Raspberry Pi.
  • Use the "Versatile PB" emulation of QEMU. Don't forget to replace the kernel.
flakeshake
  • 6,244
  • 35
