Edit: I found the possible culprit, see end of question
I have started off Jessie, and I need the Pi to be able to connect to various Wi-Fi networks (it will get sent away, so it "just needs to work"). I have had no issues with two different networks here, but the one at my place is giving me headaches. For some reason, the Pi connects to the network (WPA) but does not get assigned a correct IP address, nor gateway. I have run out of ideas, so I will just dump all the various information I have:
$ sudo ifconfig wlan0
wlan0     Link encap:Ethernet  HWaddr b8:27:eb:24:80:03
          inet addr:169.254.147.2  Bcast:169.254.255.255  Mask:255.255.0.0
          inet6 addr: fe80::a881:c8dd:3d57:eb33/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:363 errors:0 dropped:361 overruns:0 frame:0
          TX packets:41 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:105784 (103.3 KiB)  TX bytes:10547 (10.2 KiB)
In comparison, my desktop laptop with Debian gives me correct IP in the 10.0.0.x range:
$ sudo ifconfig wlp1s0
wlp1s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.0.0.18  netmask 255.255.255.0  broadcast 10.0.0.255
        inet6 fe80::47a5:8d5d:5cb9:285c  prefixlen 64  scopeid 0x20<link>
        ether b8:8a:60:a7:09:1d  txqueuelen 1000  (Ethernet)
        RX packets 28228503  bytes 35436324026 (33.0 GiB)
        TX packets 17543384  bytes 4640642944 (4.3 GiB)
So the problem extends to the missing gateway:
$ route -n
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
169.254.0.0     0.0.0.0         255.255.0.0     U     303    0        0 wlan0
Again, in comparison my working laptop:
$ sudo route -n
0.0.0.0         10.0.0.138      0.0.0.0         UG    600    0        0 wlp1s0
10.0.0.0        0.0.0.0         255.255.255.0   U     600    0        0 wlp1s0
169.254.0.0     0.0.0.0         255.255.0.0     U     1000   0        0 wlp1s0
The correct gateway is 10.0.0.138.
Here are the network settings of thi Pi:
$ cat /etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
allow-hotplug wlan1
iface wlan1 inet manual
And
$ cat /etc/dhcpcd.conf
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU.
# Some interface drivers reset when changing the MTU so disabled by default.
#option interface_mtu
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
# A hook script is provided to lookup the hostname if not set by the DHCP
# server, but it should not be run by default.
nohook lookup-hostname
# interface eth0
# static ip_address=192.168.0.11/24
# static routers=192.168.0.1
# static domain_name_servers=192.168.0.1
(I normally use a static IP on the ethernet for chatting with the laptop; as you can see, I have disabled that here to ensure there is no interference; for the record, eth0 is also not plugged in)
Wi-Fi memory:
$ sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
country=AT
network={
    ssid="my-network's ssid"
    priority=0
    psk="correct-password"
    key_mgmt=WPA-PSK
And finally, the dhcp attempt:
$ sudo dhcpcd -T wlan0
dhcpcd[1213]: version 6.7.1 starting
dhcpcd[1213]: wlan0: IPv6 kernel autoconf disabled
dhcpcd[1213]: DUID 00:01:00:01:1f:77:66:4e:b8:27:eb:24:80:03
dhcpcd[1213]: wlan0: IAID eb:24:80:03
dhcpcd[1213]: wlan0: soliciting a DHCP lease
dhcpcd[1213]: wlan0: soliciting an IPv6 router
dhcpcd[1213]: wlan0: no IPv6 Routers available
^Cdhcpcd[1213]: received signal INT from PID 0, stopping
dhcpcd[1213]: exited
And consequently
$ cat /etc/resolv.conf
# Generated by resolvconf
So nothing works:
$ ping 8.8.8.8
connect: Network is unreachable
I can do a manual trick, setting the IP with sudo ifconfig wlan0 10.0.0.66 and sudo route add default gw 10.0.0.138, after that I can ping IPs, but DNS is still not working. In any case, it's not a solution, because someone else will boot the Pi in another place and can't do manual IP configuration.
Edit: After seeing some comments about the dhcpcd -T, I thought that IP v6 might be the problem. I found this question; and hurray, this makes the system work:
sudo dhclient -4 -v wlan0
Now my questions are:
  1. What would be the correct way to make this permanent? I tried create this /etc/sysctl.d/local.conf as suggested, but it doesn't have any effect, after a reboot I have to run the above dhclient command again.
  2. Do I create a new possible problem for other Wi-Fi hot spots? In other words, can this setting lead to a situation where my system doesn't connect to a Wi-Fi network that it previously hadn't had any issues with?
0__
  • 522
