I spend the whole day to understand how to use the Raspberry (1 B+) as access point with the awus036nha with scratch, following this guide, Setting up a Raspberry Pi as an access point in a standalone network (NAT), but can't start hostapd after boot, wpa_supplicant is disabled:
sudo nano /etc/dhcpcd.conf
.(blablabla)
# fallback to static profile on eth0
#interface eth0
#fallback static_eth0
interface wlan0
static ip_address=192.168.2.1/24
nohook wpa_supplicant
I have noticed that I need to kill hostapd after boot with
sudo killall hostapd ,
and then restart again to make it works with
 sudo hostapd /etc/hostapd/hostapd.conf
and with this, everything works... but the auto start not, I've already added at /etc/default/hostapd
DAEMON_CONF="/etc/hostapd/hostapd.conf"
and did an
 sudo apt-get update
 sudo apt-get upgrade
Any suggestion?
EDIT: doing
sudo systemctl enable hostapd
pi@raspberrypi:~ $ sudo systemctl status hostapd
hostapd.service - LSB: Advanced IEEE 802.11 management d
Loaded: loaded (/etc/init.d/hostapd; generated; vendor
Active: active (running) since Sun 2018-08-05 14:34:26
Docs: man:systemd-sysv-generator(8)
Process: 328 ExecStart=/etc/init.d/hostapd start (code=e
CGroup: /system.slice/hostapd.service
└─466 /usr/sbin/hostapd -B -P /run/hostapd.pid
ago 05 14:34:18 raspberrypi systemd[1]: Starting LSB: Adva
ago 05 14:34:26 raspberrypi hostapd[328]: Starting advance
ago 05 14:34:26 raspberrypi systemd[1]: Started LSB: Advan
lines 1-11/11 (END)...skipping...
● hostapd.service - LSB: Advanced IEEE 802.11 management daemon
Loaded: loaded (/etc/init.d/hostapd; generated; vendor preset: enabled)
Active: active (running) since Sun 2018-08-05 14:34:26 CEST; 2min 28s ago
Process: 328 ExecStart=/etc/init.d/hostapd start (code=exited,
status=0/SUCCESS)
ago 05 14:34:18 raspberrypi systemd[1]: Starting LSB: Advanced IEEE 802.11 m
management daemon...
ago 05 14:34:26 raspberrypi hostapd[328]: Starting advanced IEEE 802.11
management: hostapd.
ago 05 14:34:26 raspberrypi systemd[1]: Started LSB: Advanced IEEE 802.11
management daemon.
EDIT2:
sudo nano  /etc/init.d/hostapd
....(blabla)...
PATH=/sbin:/bin:/usr/sbin:/usr/bin
DAEMON_SBIN=/usr/sbin/hostapd
DAEMON_DEFS=/etc/default/hostapd
DAEMON_CONF=
NAME=hostapd
Greenonline
  • 2,969
  • 38
Stefano
  • 41
I've resolved by myself, I have made a script in bash that restart the hostapd service with
 #!/bin/bash
 service hostapd restart
and make it executable with
  sudo chmod +x /location/file
then used
 sudo visudo
and make the file executable without asking for password, adding in the file
 [your_username] ALL= NOPASSWD: /location/of/file
went in
  cd /home/pi/.config/autostart
  sudo nano name.desktop
and adding in the file
 [Desktop Entry]
 Encoding=UTF-8
 Type=Application
 Name=name
 Comment=restart hostapd service
 Exec=sudo lxterminal -e "/location/of/the/file"
This file will be executable after the GUI is loaded, and this file will call the bash script in sudo mode, without asking for password, restarting hostapd service after boot... maybe is not the smartest solution but I spent two days on it and didn't found much help.
EDIT: My fault, I had edited (following another guide) /etc/network/interfaces and my configuration at /etc/dhcpcd.conf were not loaded, so I just uncommented the interface configuration and everything worked as expected.
Greenonline
  • 2,969
  • 38
Stefano
  • 41
My hostapd2.6 also failed to start on raspbian stretch, just adding it to crontab will works.
crontab -e
@reboot sleep 60 && /usr/sbin/hostapd -B /etc/hostapd/hostapd.conf
Or the sleep might not be needed in your situation
@reboot /usr/sbin/hostapd -B /etc/hostapd/hostapd.conf
Well I found another solution: add the following line to the end of /etc/default/hostapd
Iceberg
  • 121
This worked for me. I'm suspicious that hostapd is conflicting or dependent on another process starting up. It basically causes hostapd to start after the other services. I'm actually surprised to see all of the symlinks S01 and the lack of a networking symlink but my Linux knowledge is probably a bit dated at this point. I was expecting something like S03networking and S04sshd.
sudo mv /etc/rc5.d/S01hostapd /etc/rc5.d/S02hostapd
Note rc5 maps to the runlevel.
runlevel
N 5
