I have Motion running on my Pi.
I want to be able to access the Motion interface/feed (hosted on <pi ip>:8081) to be accessible both via WiFi and via Ethernet with a static address and DHCP for both the interfaces. I would also prefer to keep them isolated from each other/not have them bridged.
Have configured wlan0 to act as a wireless access point (as give in this guide, but without the Routing/Masquerade).
This worked as expected.
After this I tried doing the same for Ethernet, so I also added a static address for eth0 to /etc/dhcpcd.conf and added entry to enable dnsmasq for eth0 (via a file in etc/dnsmasq.d/).
The static address for eth0 is different from wlan0 and so are the dhcp-range.
I can only access via one of the interfaces at a time. So if I boot up the Pi connected with the Ethernet, I can access Motion on the Pi (via Ethernet). However, access via WLAN fails. On the other hand, with Ethernet unplugged I can access Motion via WLAN.
How do I enable both the Eth and Wlan to work independently with DHCP and static IP on both of them to access Motion on the Pi?
Also, is it possible to have the same static IP address for both the interfaces?
Edit: Output of various commands as asked by @eftshift0:
$ ip link show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
link/ether b8:27:eb:c3:d7:6b brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
link/ether b8:27:eb:96:82:3e brd ff:ff:ff:ff:ff:ff
$ip addr show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
inet 127.0.0.1/8 scope host lo
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
inet 192.168.0.1/24 brd 192.168.0.255 scope global eth0
inet6 fe80::f98e:1b2a:d923:6474/64 scope link
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
inet 192.168.0.2/24 brd 192.168.0.255 scope global wlan0
inet6 fe80::496:128:e7ec:f5b0/64 scope link
$ netstat -lntp | grep 8081
(Not all processes could be identified, non-owned process info
will not be shown, you would have to be root to see it all.)
tcp 0 0 0.0.0.0:8081 0.0.0.0:* LISTEN -
