9
I dusted off a Pi 1, which is armv6, then installed Raspbian on it. The base OS works, but many of the packages I install won't even start- they say illegal instruction. That's because the armhf binary packages are being installed, which isn't compatible with the Pi1.
Here's an example, looking at vim-common in apt show:
Download-Size: 339 kB
APT-Manual-Installed: yes
APT-Sources: http://mirrordirector.raspbian.org/raspbian stable/main armhf Packages
Description: Vi IMproved - enhanced vi editor - compact version
Aside from installing an ancient kernel, how do I tell apt to not install the 'wrong' version of the binaries?
Here's what my sources.list contains (in part). Nowhere does it say armv6, armv7, armel, or armhf.
$ cat /etc/apt/sources.list.d/archive_raspbian_org_raspbian.list deb https://archive.raspbian.org/raspbian jessie main contrib non-free deb-src https://archive.raspbian.org/raspbian jessie main contrib non-free
300D7309EF17
  • 1,394
Both Raspbian and Debian pride themselves in suppporting the "armhf" architecture. Of course, they mean two different things !
  • Raspbian "armhf": ARMv6 + VFPv2
  • Debian "armhf": ARMv7
Your scenario is impossible without mixing debian.org and raspbian.org/raspberrypi.org packages. You must have mixed those repositories in the past or are still using mixed up repositories.
Check the output of
apt-cache policy name-of-offending-package
Raspbian "armhf" has always worked on any Raspberry Pi. Debian "armhf" only works on newer Pis with ARMv7 CPU (first released ~ 2015).
flakeshake
  • 6,244
  • 35
