I have a headless raspberry pi zero. It is configured to be connected to home network and my mobile hotspot (Android phone). When I am home, I would like it to get a static IP, where I know I can connect to it (works fine).
But when it connects to my mobile hotspot, it can't get that static IP. In that case, I want it to fall back to dynamic IP. How can I configure dhcpcd.conf to achieve that?
Most information I can find is the other way around (when DHCP server fails). Some claimed that this is impossible (which I doubt). I don't want to change dhcpcd.conf each time I move from one network to another.
Why is this such a problem? Why can't I configure mobile hotspot to accept same static IP? Android is simply primitive in this regard. It only allows a certain IP range (192.168.43.0/24). But I need to connect to the pi on the mobile network. I can find the dynamic IP either on the 16x2 display or with nmap. The weird issue is that notification on my phone tells me that there are 2 clients connected but nmap, doesn't find the rpi. I suppose on physical/data link layer RPi is connected but can't get the static IP. Only way to get around is to make sure RPi can get a dynamic IP, if static IP doesn't work out.
Edit - Summary of the discussions below: It is not possible to detect failed static IP. Client act like the IP belongs to it, while router won't deliver the packages to that IP. Client things that it is connected, while it is not. Actually, DHCP server delivers IP addresses. But my router's DHCP server is aware of clients requesting static IP and allows it (seen under DHCP clients at router's web panel), while other clients request a dynamic IP. However, my router doesn't allow a fixed IP on specified clients (e.g. my mac address).
I am looking for a configuration like it is done at Apple Mac OS, where users can define dynamic or static IP for each WiFi access point separately.
Saren Tasciyan
  • 181
Seems there is some misunderstanding of a static ip address. This isn't given by any dhcp server. It is configured statically in local config files like /etc/dhcpcd.conf or /etc/network/interfaces or /etc/systemd/network/iface.network. And yes, it is static and will never change and be overwritten by a dhcp response.
But I understand your problem. You can fix it by using - I call it - a "fix ip address" that is given by the dhcp server. Configure your raspi using a dhcp client to get ip addresses from a dhcp server, not static ip address at all. That's the default. Most dhcp server can give a specific host always the same ip address. The host is identified by it's mac address. So when you are at home, configure that dhcp server to give your raspi a "fix ip address". You have to look how it is done on your dhcp server. For example the most used dhcp server on a raspi is dnsmasq. In its config file man dnsmasq.conf you find this example:
# Always allocate the host with ethernet address 11:22:33:44:55:66
# The IP address 192.168.0.60
dhcp-host=11:22:33:44:55:66,192.168.0.60
You can also set other options using the host name or give an infinite lease or others. Have a look at the man page. But you have to configure the dhcp server on your home router.
Ingo
  • 42,961
  • 207
I'm assuming you run latest Raspbian i.e stretch
Your last sentence asks "define dynamic or static IP for each WiFi access point separately" - you can use /etc/dhcpcd.conf to achieve this, in that you can define static IP address for a given SSID (one or more, simply repeat for each SSID), for any other SSID's will default to dynamic IP
Simply add to the end of that file, something like
ssid your-ssid
    static ip_address=192.168.1.19/24
    static routers=192.168.1.1
    static domain_name_servers=192.168.1.1
(of course, change your-ssid and the IP addresses as appropriate to your needs)
Jaromanda X
  • 2,481
