70
There have been a few articles floating around online over the last few years about building a cluster of computers at home - here for example.
The Pi strikes me as a good platform for building / testing this kind of thing due to their low cost; should "generic" guides like this transfer over to the Pi pretty easily, or is there anything specifically I should be aware of when attempting such a project?
Alex Chamberlain
  • 15,638
berry120
  • 10,984
  • 53
  • 63
7 Answers7
35
I suggest looking at Dispy - the distributed computation python module.
To run a program on a number of Raspberry Pi's (nodes) from a PC (server - assume IP is 192.168.0.100):
  • Install an operating system on each RasPi
  • Attach each RasPi to your network. Find the IP (if dynamic), or set up static IPs.
    (Let's assume that you have three nodes, and their IPs are 192.168.0.50-52)
  • Set up Python (if not already), install dispy, then run dispynode.py -i 192.168.0.100 on each RasPi. This will tell dispynode to receive job information from the server.
  • On the PC (the server), install dispy, then run the following python code:
#!/usr/bin/env python
import dispy
cluster = dispy.JobCluster('/some/program', nodes=['192.168.0.50', '192.168.0.51', '192.168.0.52'])
You can also replace /some/program with a python function - e.g. compute.
You can also include dependencies such as python objects, modules and files (which dispy will transfer to each node) by adding depends=[ClassA, moduleB, 'file1']
Alex L
  • 7,615
  • 44
  • 53
10
You should be aware of the work that has already been done - there's even a name for a cluster of RasPi boxen. The Embedded Linux Wiki says a Bramble is defined as "a Beowulf cluster of Raspberry Pi devices". Raspberry Pi Homebrew has a number of posts about Brambles, and see also the Foundation's own forum.
mlp
  • 323
Some guys at Southampton Uni have put together a cluster and written a detailed overview of their work at http://www.southampton.ac.uk/~sjc/raspberrypi/.
Alex Chamberlain
  • 15,638
It is completely possible, but the biggest problem is attainability. It is an idea I would not only think workable, but useful as you could go with the idea of portable parallel computing. As far as specifics, coding languages like FORTRAN and C++ will do best.
Look at beowulf.org for more on cluster computing
Alex Chamberlain
  • 15,638
Kaminara
  • 437
This is reply to Guido Garcia's post above regarding 'dispy' - I can't figure out how to reply to his post.
When a program ('/bin/ls') is distributed with 'dispy' for parallel execution, then that program on the client machine is transferred to each of the nodes (to '/tmp'). This is so that the user developed program on the client machine is transferred without having NFS or some shared diretory. This works with binary programs only when nodes and client architectures are compatible. In your case, I am guessing that client architecture is different from that of the remote nodes and a node can't execute the binary '/bin/ls' transferred from the client. If you want to execute /bin/ls on each node, it may easier to write a Python function or program to print the directory (e.g., using os.listdir) and distribute that instead of binary executable.
There's also http://pi.interworx.com if you want a full featured control panel with it. They have instructions up on this page on how to replicate, but you'll have to be patient as that subdomain tself is running from a Rasberry Pi cluster. Here's a photo in case it goes down:
http://www.facebook.com/photo.php?fbid=596262440393836&set=a.244167858936631.60071.170159826337435&type=1
Corey
  • 111
The main options I see for cluster management on Raspberry Pi are; Docker Swarm k3s and microk8s. I found Docker Swarm easiest to set up and work with (using RPi 3Bs), and adequate for my purposes. The Kubernetes options were also fairly straightforward to set up though.
Set up guides:
Docker Swarm
k3s
microk8s
Another "vanilla" way of doing it would be to create a script that scp copies dockerfiles then ssh connects to the hosts in turn and then runs them in turn.
Watch-it:
I found I needed to install extra modules (on Ubuntu 22, 3B) to get swarm mode to work seamlessly:
sudo apt install linux-modules-extra-raspi
Lee
  • 209
