New Pi user here - I popped it out of the box and immediately went to work trying to turn it into a web server. I managed to install Apache, PHP5 and MySQL5 no problem. I can SSH in without issue.
However, Apache doesn't seem to want to start. I get this error:
$ /etc/init.d/apache2 start
[....] Starting web server: apache2/usr/sbin/apache2ctl: 87: ulimit: error setting limit (Operation not permitted)
apache2: apr_sockaddr_info_get() failed for memlbiometric
apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1 for ServerName
(13)Permission denied: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
Unable to open logs
Action 'start' failed.
The Apache error log may have more information.
 failed!
I have to admit, I'm a little flummoxed. Whats the issue here?
syb0rg
  • 8,178
  • 38
user8741
  • 141
is deprecated, you should use new interface for starting services:
$ sudo service apache2 start
lenik
  • 11,533
  • 37
Based on the description you gave in your question, I don't believe you performed the full setup process. From the tutorial I linked in my comment:
A little Debian/Apache foreknowledge: The default Debian install of Apache will be configured to run in the "www-data" user space, and use the "www-data" group. The version of Debian used for this guide (debian6-19-04-2012) already includes the "www-data" user, but not the "www-data" group. The following commands will create the "www-data" group, and add the "www-data" user to the newly-created group:
# Create the www-data group
sudo addgroup www-data
sudo adduser www-data www-data
A touch more Debian/Apache foreknowledge: The default Debian install of Apache will be configured to serve HTML pages from the "/var/www" folder. While this folder is created during the Apache2 install process, it will likely be created with the wrong owner:group (root:root). We can ensure a smoother install and successful running of Apache2 by creating this folder ahead of time and changing owner:group to www-data:www-data.
# Create the /var/www folder and reassign ownership of the folder (and any files/subfolders)
sudo mkdir /var/www
sudo chown -R www-data:www-data /var/www
syb0rg
  • 8,178
  • 38
The issue is that apache couldn't listen on port 80
That's because you didn't run /etc/init.d/apache2 start as root.
If you run it as root, it should be able to start fine. Apache being unable to resolve a FQDN will not stop it from starting.
Lawrence
  • 2,692
