13
I'm using a 4GB SD card, formatted from a Windows PC with the Debian image. Here's the output of df -h:
Filesystem            Size  Used Avail Use% Mounted on
tmpfs                  94M     0   94M   0% /lib/init/rw
udev                   10M  156K  9.9M   2% /dev
tmpfs                  94M     0   94M   0% /dev/shm
rootfs                1.6G  1.5G     0 100% /
/dev/mmcblk0p1         75M   28M   47M  37% /boot
Where's all my extra space? There's about 2GB is missing!
tlhIngan
  • 3,372
  • 33
Tom Medley
  • 4,089
  • 33
  • 46
It's there, but not set up as available space.
You can either use the remaining space as a separate drive/volume or resize the partition to the full 4gb
David Sykes
  • 1,434
  • 28
Because the image that you flashed to the Pi is only 2GB, that's all the space the root partition can see. Either you can resize the root partition or create a new one with fdisk.
Jivings
  • 22,656
  • 94
  • 140
