My setup is that I have two raspberry Pis connected directly via ethernet (enxb827eb9c0ecf), let's call them Pi 1 and Pi 2. Pi 1 is also connected wirelessly to my home router. I would like to be able to send a file from Pi 2 to Pi 1 over ethernet and then upload that file online using the WiFi on Pi 1.
I am trying to connect to the internet over wlan0 on Pi 1, but Pi 1 seems to prioritize attempting to connect to the internet via ethernet (where I am not connected to the web but to Pi 2). I am running Raspbian Stretch (so all the tutorials saying to edit /etc/network/interfaces are outdated according to this guide).
I have deleted /etc/ifplugd/action.d/action_wpa so that WiFi on Pi 1 connects fine but it seems to prioritize using the eth0 connection when reaching out to the web. (I can ping both Pis back and forth totally fine)
Note that all the following configurations and details are for Pi 1
/etc/dhcpcd.conf
interface wlan0
static ip_address=192.168.2.143/24
static routers=192.168.2.1
static domain_name_servers=192.168.2.1
interface enxb827eb9c0ecf
static ip_address=192.168.3.142/24
/etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
country=CA
network={
        ssid="********"
        psk="********"
        key_mgmt=WPA-PSK
ifconfig
     enxb827eb9c0ecf: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
             inet 192.168.2.142  netmask 255.255.255.0  broadcast 192.168.2.255
             inet6 fe80::96ca:62e8:edea:e3e3  prefixlen 64  scopeid 0x20<link>
             ether b8:27:eb:9c:0e:cf  txqueuelen 1000  (Ethernet)
             RX packets 594  bytes 37223 (36.3 KiB)
             TX packets 590  bytes 27674 (27.0 KiB)
     lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
             inet 127.0.0.1  netmask 255.0.0.0
             inet6 ::1  prefixlen 128  scopeid 0x10<host>
             loop  txqueuelen 1000  (Local Loopback)
             RX packets 385  bytes 36222 (35.3 KiB)
             TX packets 385  bytes 36222 (35.3 KiB)
     wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
             inet 192.168.2.143  netmask 255.255.255.0  broadcast 192.168.2.255
             inet6 fe80::df3f:baa8:e17c:aef4  prefixlen 64  scopeid 0x20<link>
             ether b8:27:eb:c9:5b:9a  txqueuelen 1000  (Ethernet)
             RX packets 1147  bytes 118792 (116.0 KiB)
             TX packets 667  bytes 102957 (100.5 KiB)
iwconfig
 lo        no wireless extensions.
 wlan0     IEEE 802.11  ESSID:"******"
           Mode:Managed  Frequency:2.437 GHz  Access Point: 40:C7:29:4E:4D:FE
           Bit Rate=72.2 Mb/s   Tx-Power=31 dBm
           Retry short limit:7   RTS thr:off   Fragment thr:off
           Power Management:on
           Link Quality=70/70  Signal level=-28 dBm
           Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
           Tx excessive retries:0  Invalid misc:0   Missed beacon:0
 enxb827eb9c0ecf  no wireless extensions.
cat /etc/resolv.conf
 # Generated by resolvconf
 nameserver 192.168.2.1
cat /etc/network/interfaces
 # Include files from /etc/network/interfaces.d: source-directory /etc/network/interfaces.d
ip link show
 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN
 mode DEFAULT group default qlen 1000
     link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
 2: enxb827eb9c0ecf: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc
 pfifo_fast state UP mode DEFAULT group default qlen 1000
     link/ether b8:27:eb:9c:0e:cf brd ff:ff:ff:ff:ff:ff
 3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP
 mode DORMANT group default qlen 1000
     link/ether b8:27:eb:c9:5b:9a brd ff:ff:ff:ff:ff:ff
ip addr show
     inet 127.0.0.1/8 scope host lo
     inet6 ::1/128 scope host
 2: enxb827eb9c0ecf: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP
     inet 192.168.3.142/24 brd 192.168.3.255 scope global enxb827eb9c0ecf
     inet6 fe80::96ca:62e8:edea:e3e3/64 scope link
     inet 192.168.2.143/24 brd 192.168.2.255 scope global wlan0
     inet6 fe80::df3f:baa8:e17c:aef4/64 scope link
ip route show
 default via 192.168.2.1 dev wlan0 src 192.168.2.143 metric 303
 192.168.2.0/24 dev wlan0 proto kernel scope link src 192.168.2.143 metric 303
 192.168.3.0/24 dev enxb827eb9c0ecf proto kernel scope link src 192.168.3.142 metric 202
Matt
  • 466
You should not have two interfaces connected to the same network... unless you know what you are doing (there are some scenarios where it might be useful or necessary, but you have to mean it for it to make sense and then you have to face problems like this if both interfaces are up at the same time).
Anyway, what happens is that when you try to reach your rpi from some other host (say, ping), traffic will reach the rpi by the interface you intended (by the IP) but, when replying back, the "routing decision engine" might decide to send the response through the other interface. When traffic reaches the originating host the "expected response" is coming from one IP that the originating host didn't expect traffic to come from and so the connection breaks.
eftshift0
  • 800
