I'm pretty new to Raspberry and I searched the net for a while now trying to find a good and simple answer to this question.
Ok, so I have a network that is connected to the internet. I want to start a new network for IOT devices around my workplace to do and alert me on various things. I'm using HomeAssistant for the system, and I have a separate router for the IOT network.
My question is how can I set it all up so the Raspberry will be connected to the internet through the wifi and connected to the IOT network through the ethernet?
I heard they can't work together at the same time and I want it to either switch between them automatically or if it does work if someone can point me in the right direction of where to read or what to look for that will really help me a lot.
I run the Raspberry Pi 3 model B+.
EDIT: I posted the solution as an answer. at least what has worked for me for the last few days now.
Sagi Rokach
  • 71
Yes, it is possible. The rpi loaded with raspbian (or any other GNU/Linux based distro) can be used as a router to connect different networks, only that technically there are a number of different subjects related to networking that you have to be able to cope and solve in order to get it working. So... the questions:
  • Do you want to set up a new network segment for the wired network so that the RPI and the IOT devices can see each other? The answer there is probably "yes", right?
  • Will you use a dhcp service on this network segment so that all devices get automagically set up? Will the DHCP service run on the RPI? If that's the case, you will have to use dnsmasq, probably (there are other services available, like udhcpd, for example but dnsmasq also helps with the DNS set up).
  • Do you want your IOT devices to be reachable to devices outside of the RPI (like, traffic coming from the wireless). This will probably require some hacking on the routing of your whole network (or at least the boxes that you want to be able to reach the IOT devices) to teach them that in order to reach network segment x.x.x.x/24 they have to throw the traffic through the rpi.
  • Do you want your IOT devices to be able to reach devices outside of the IOT network while not making this network accessible to devices outside of this segment? This means you will need to set up some DNAT or masquerade on the RPI.
eftshift0
  • 800
If the Pi is a regular node on both networks, this is just a matter of adding a route for the non-internet connected IOT subnet; your default route will be the WLAN, since that's what you want to use to connect to anything that isn't part of the IOT subnet.
If the CIDR of the IOT subnet is 10.100.0.0/16, the router for it is at 10.100.0.1, and the ethernet interface is eth0 (note this presumes that interface is up, connected, and has a 10.100.0.0/16 IP address):
sudo ip route add 10.100.0.0/16 via 10.100.0.1 dev eth0
ip route with no other commands will show the current routing table (you don't need sudo for that). It might now look like this:
default via 192.168.0.1 dev wlan0
192.168.0.0/24 dev wlan0 proto kernel scope link src 192.168.0.20
The first line is the default route mentioned earlier; everything that doesn't match the other two is presumed to go through the 192.168.0.1 router connected via wlan0 (this may not be the same, it's whatever your wifi link is). The second line is a direct broadcast route on the WLAN. The last one is for the IOT subnet.
You can add this to your networking configuration to make it permanent, but alas, I don't use the conventional configuration system so I don't know how to do that (pretty sure it is just adding the last part of that ip route add command to a file somewhere).
so here is what I got from the ip route command:
default via 192.168.1.1 dev eth0 src 192.168.1.50 metric 202
default via 10.0.0.138 dev wlan0 src 10.0.0.101 metric 303
You should not have two default routes. Try:
sudo ip route del default via 10.0.0.138 dev wlan0 src 10.0.0.101
After connecting the pi over the wlan to the internet network and through eth0 to the IOT network, the mqtt I run over the IOT network works, but the notifications that worked before stopped working. I tried installing some packages but it wouldn't find them and won't install them, that's when I started thinking it was a problem with the routing table like @goldilocks suggested.
pi@hassbian:~ $ ip route
10.0.0.0/24 dev wlan0 proto kernel scope link src 10.0.0.101 metric 303
192.168.1.0/24 dev eth0 proto kernel scope link src 192.168.1.50 metric 202
In order to work through the internet which is run on the 10.0.0.0/24 network I needed to edit the /etc/dhcpcd.conf file and add at the end of the file:
interface wlan0
metric 200
interface eth0
metric 300
Assigning lower metric give precedence over the other in terms of where the internet connection comes from (at least that is what I understood). This will result in the wlan0 making all the internet connection.
I hope this will help people solve their connection problems.
Sagi Rokach
  • 71
If the 2 networks have DHCP servers (operating on their own network - using multiple DHCP servers on a single network is problematical) then the Pi should obtain the necessary configuration parameters, then it should work.
No additional configuration should be required if using the default dhcpcd network manager. route will show the final routing. If this cannot be done automatically then you may need to manually configure the routing table as suggested by goldilocks - this is more involved, as the table is normally automatically configured and will overwrite manual configuration.
