I'm trying to setup the RPI3 with these two network features (using built-in hardware only):
  • Isolated network with Wifi Access Point and Ethernet. A) Sharing same domain "pi.lan". B) Sharing one DHCP service/address space, so Ethernet and Wifi clients can talk to each other.
  • Wifi Station connection to another internet Wifi access point, to be able to update and the RPI and install software:
Current approach (suggestions for simplification appreciated!):
  • ap0 - access point
  • br0 - bridging ap0 and eth0, providing DNS and DHCP service, domain pi.lan
  • wlan0 - wifi station
Installed software:
apt-get install hostapd dnsmasq bridge-utils
Here is what I go so far. Adding new interface ap0 for wifi access point, so wlan0 can be used for wifi station:
/etc/udev/rules.d/70-persistent-net.rules (mac same as wlan0, I read that should work):
SUBSYSTEM=="ieee80211", ACTION=="add|change", ATTR{macaddress}=="b8:27:eb:bf:d3:81", KERNEL=="phy0", \
  RUN+="/sbin/iw phy phy0 interface add ap0 type __ap", \
  RUN+="/bin/ip link set ap0 address b8:27:eb:bf:d3:81"
/etc/dhcpcd.conf :
interface br0
static ip_address=10.0.0.1/24
static routers=10.0.0.1
static domain_name_servers=10.0.0.1
/etc/hostapd/hostapd.conf :
interface=ap0
bridge=br0
#driver=nl80211
ssid=accesspoint1
hw_mode=g
channel=7
wmm_enabled=0
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=notmypassword
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
/etc/default/hostapd (uncomment this line):
DAEMON_CONF="/etc/hostapd/hostapd.conf"
/etc/wpa_supplicant/wpa_supplicant.conf :
update_config=1
country=US
network={
    ssid="mywifi"
    psk=notmypassowrd
/etc/network/interfaces :
auto lo br0 ap0 eth0
iface lo inet loopback
iface br0 inet static
    address 10.0.0.1
    network 10.0.0.0
    netmask 255.255.255.0
    bridge_ports ap0 eth0
allow-hotplug wlan0
iface wlan0 inet dhcp
iface ap0 inet manual
iface eth0 inet manual
/etc/dnsmasq.conf :
dhcp-mac=set:client_is_a_pi,B8:27:EB:*:*:*
dhcp-reply-delay=tag:client_is_a_pi,2
no-dhcp-interface=lo,wlan0,ap0,eth0
addn-hosts=/etc/hosts_dnsmasq
no-resolv
domain-needed
bogus-priv
domain=pi.lan
expand-hosts
local=/pi.lan/
interface=br0
bind-interfaces
dhcp-range=lan,10.0.0.10,10.0.0.200,12h
#set default gateway
dhcp-option=lan,3,10.0.0.1
#set DNS server
dhcp-option=lan,6,8.8.8.8
cat /etc/hosts_dnsmasq
10.0.0.1        pi
10.0.0.111      laptop
Some useful info I'm using a hypriot docker host as starting point, it adds some additional network stuff which we should not have to mess with, but it appears in the dumps below.
ip -d addr
root@black-pearl:/home/pirate# ip -d addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 promiscuity 0 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
    inet 127.0.0.1/8 scope host lo
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast master br0 state DOWN group default qlen 1000
    link/ether b8:27:eb:ea:86:d4 brd ff:ff:ff:ff:ff:ff promiscuity 1
    bridge_slave state disabled priority 32 cost 100 hairpin off guard off root_block off fastleave off learning on flood on port_id 0x8002 port_no 0x2 designated_port 32770 designated_cost 0 designated_bridge 8000.b8:27:eb:bf:d3:81 designated_root 8000.b8:27:eb:bf:d3:81 hold_timer    0.00 message_age_timer    0.00 forward_delay_timer    0.00 topology_change_ack 0 config_pending 0 proxy_arp off proxy_arp_wifi off mcast_router 1 mcast_fast_leave off mcast_flood on numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
    link/ether b8:27:eb:bf:d3:81 brd ff:ff:ff:ff:ff:ff promiscuity 0 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
    inet 192.168.0.129/24 brd 192.168.0.255 scope global wlan0
4: ap0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master br0 state UP group default qlen 1000
    link/ether b8:27:eb:bf:d3:81 brd ff:ff:ff:ff:ff:ff promiscuity 1
    bridge_slave state forwarding priority 32 cost 100 hairpin off guard off root_block off fastleave off learning on flood on port_id 0x8001 port_no 0x1 designated_port 32769 designated_cost 0 designated_bridge 8000.b8:27:eb:bf:d3:81 designated_root 8000.b8:27:eb:bf:d3:81 hold_timer    0.00 message_age_timer    0.00 forward_delay_timer    0.00 topology_change_ack 0 config_pending 0 proxy_arp off proxy_arp_wifi off mcast_router 1 mcast_fast_leave off mcast_flood on numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
5: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    bridge forward_delay 1500 hello_time 200 max_age 2000 ageing_time 30000 stp_state 0 priority 32768 vlan_filtering 0 bridge_id 8000.b8:27:eb:bf:d3:81 designated_root 8000.b8:27:eb:bf:d3:81 root_port 0 root_path_cost 0 topology_change 0 topology_change_detected 0 hello_timer    0.00 tcn_timer    0.00 topology_change_timer    0.00 gc_timer  182.47 group_fwd_mask 0 group_address 01:80:c2:00:00:00 mcast_snooping 1 mcast_router 1 mcast_query_use_ifaddr 0 mcast_querier 0 mcast_hash_elasticity 4 mcast_hash_max 512 mcast_last_member_count 2 mcast_startup_query_count 2 mcast_last_member_interval 100 mcast_membership_interval 26000 mcast_querier_interval 25500 mcast_query_interval 12500 mcast_query_response_interval 1000 mcast_startup_query_interval 3125 nf_call_iptables 0 nf_call_ip6tables 0 nf_call_arptables 0 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
    inet 10.0.0.1/24 brd 10.0.0.255 scope global br0
6: docker0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default
    link/ether 02:42:2f:12:fe:19 brd ff:ff:ff:ff:ff:ff promiscuity 0
    bridge forward_delay 1500 hello_time 200 max_age 2000 ageing_time 30000 stp_state 0 priority 32768 vlan_filtering 0 bridge_id 8000.2:42:2f:12:fe:19 designated_root 8000.2:42:2f:12:fe:19 root_port 0 root_path_cost 0 topology_change 0 topology_change_detected 0 hello_timer    0.00 tcn_timer    0.00 topology_change_timer    0.00 gc_timer  204.32 group_fwd_mask 0 group_address 01:80:c2:00:00:00 mcast_snooping 1 mcast_router 1 mcast_query_use_ifaddr 0 mcast_querier 0 mcast_hash_elasticity 4 mcast_hash_max 512 mcast_last_member_count 2 mcast_startup_query_count 2 mcast_last_member_interval 100 mcast_membership_interval 26000 mcast_querier_interval 25500 mcast_query_interval 12500 mcast_query_response_interval 1000 mcast_startup_query_interval 3125 nf_call_iptables 0 nf_call_ip6tables 0 nf_call_arptables 0 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
    inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
8: veth5004b64@if7: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master docker0 state UP group default
    link/ether f2:ab:67:74:c6:be brd ff:ff:ff:ff:ff:ff link-netnsid 0 promiscuity 1
    veth
    bridge_slave state forwarding priority 32 cost 2 hairpin off guard off root_block off fastleave off learning on flood on port_id 0x8001 port_no 0x1 designated_port 32769 designated_cost 0 designated_bridge 8000.2:42:2f:12:fe:19 designated_root 8000.2:42:2f:12:fe:19 hold_timer    0.00 message_age_timer    0.00 forward_delay_timer    0.00 topology_change_ack 0 config_pending 0 proxy_arp off proxy_arp_wifi off mcast_router 1 mcast_fast_leave off mcast_flood on numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
ip route
root@black-pearl:/home/pirate# ip route
default via 192.168.0.1 dev wlan0
10.0.0.0/24 dev br0 proto kernel scope link src 10.0.0.1
172.17.0.0/16 dev docker0 proto kernel scope link src 172.17.0.1
192.168.0.0/24 dev wlan0 proto kernel scope link src 192.168.0.129
bridge -d link
root@black-pearl:/home/pirate# bridge -d link
2: eth0 state DOWN : <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 master br0 state disabled priority 32 cost 100
    hairpin off guard off root_block off fastleave off learning on flood on mcast_flood on
4: ap0 state UP : <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 master br0 state forwarding priority 32 cost 100
8: veth5004b64 state UP @(null): <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 master docker0 state forwarding priority 32 cost 2
Problem 1:
When connecting to the RPI access point with another device then it will connect but immediately drop the connection again.
Problem 2:
wlan0 doesn't automatically connect after reboot. Only after ifdown - ifup the wifi station connects e.g.:
ifdown wlan0
ifup wlan0
Problem 3:
After the RPI's wifi station is connected to a router with internet connection then the name resolution seems broken:
root@black-pearl:/home/pirate# ping google.com
ping: google.com: Temporary failure in name resolution
root@black-pearl:/home/pirate# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=57 time=20.8 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=57 time=20.6 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=57 time=20.0 ms
^C
Problem 4:
When wiring a laptop to eth0 then Laptop get an IP but DNS name resolution doesn't work so I can't ping pi.pi.lan
Any hints are appreciated!!
Ingo
  • 42,961
  • 207
regexing
I have taken much effort to the answer, so I decided to move it to Access point as WiFi repeater, optional with bridge so I can it make more generic and present as an accepted answer.
Ingo
  • 42,961
  • 207
