So, I have my raspberry pi running Raspbian 9 configured using a static IP address for both WLAN0 and ETH0.
Both work if I boot with an ethernet-cable plugged in.
But, in certain situations, it happens that my pi should boot without a cable plugged in, or with the router not being alive yet. When this situation occurs, for some reason my raspberry pi will not connect to the network (as in: I can never reach it, be it by SSH or ping) untill I give it a reset.
I've read about an option "allow_hotplug" which sounds like the thing I need, but that doesn't work either (and I guess I shouldn't even be touching /etc/network/interfaces on Debian Stretch..)
Could anyone point me in the right direction? I really need this pi to be reachable on the network, even when the network is a bit slower in starting than the pi.
For reference:
/etc/network/interfaces:
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
allow-hotplug wlan1
iface wlan1 inet manual
and /etc/dhcpcd.conf:
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
# Some non-RFC compliant DHCP servers do not reply with this set.
# In this case, comment out duid and enable clientid above.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU. This is applied to DHCP routes.
option interface_mtu
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
interface wlan0
static ip_address=192.168.123.45/24
static routers=192.168.123.45
static domain_name_servers=8.8.8.8 8.8.4.4
denyinterfaces wlan0
interface eth0
static ip_address=192.168.1.199/24
static routers=192.168.1.1
