Can someone tell me if the following circuit is sane? It's a fairly standard lowside switch, but I've added an LED plus resistor. V_GS on an IRF530 is about 2v, so I assume that a small LED won't lead to excessive voltage drop.
my attempt at a circuit
If that's not okay, is there a way to wire the LED in 'parallel' with the gate?
For the record, I also have NTD5867NLs, so that's an option. I know it has a lower V_GS.
300D7309EF17
  • 1,394
It probably won't work - for 2 reasons;
  1. The LED will have a voltage drop (1.5V - 2.5V depending on type - independent of "size").
  2. The current through the LED will be ~0.5mA - you may or may not even see the glow.
You COULD run the LED (plus current limiting resistor) in parallel with the gate, but it would seem more sensible to use with the load.
