There is a 2TB Time Capsule on my home network (IP 192.168.0.1). How can I mount the Time Capsule's disk from my Raspberry Pi, automatically after reboots?
Put it in fstab.
sudo su
mkdir /mnt/timecapsule
echo "//timeCapsuleIp/Data /mnt/timecapsule cifs user=timecapsuleUsername,pass=timecapsuleUserPassword,rw,uid=1000,iocharset=utf8,sec=ntlm 0 0" >> /etc/fstab
Required cifs-utils package should be already provided on raspbian.
Of course change timecapsuleUsername and timecapsuleUserPassword. The uid=1000 sets owner of mounted files to user pi. If using other user check it's uid with id -u username. Check if "Data" folder is right for you - list resources by issuing command smbclient -Uusername -I ip-address -L.
I got adding sec=ntlm to the options, the complete command is:
sudo su
echo "//timeCapsuleIp/Data /mnt/timecapsule cifs user= timecapsuleUsername,pass= timecapsuleUserPassword,rw,uid=1000,iocharset=utf8,sec=ntlm 0 0" >> /etc/fstab
Then, run this command:
mount -a
You should no get any errors.
For me, when using a disk password on the time capsule, it only worked when I added uid=504 (which is the userID used on the macintosh mainly using the timecapsule, not the uid used on the raspberry). When I didn't put uid=504 then I got "mount error(16): Device or resource busy" back from the time capsule.
- 11
- 2
