If I install munin server from apt-get, only version 2.0.33-1 is installed which can't be started because Failed to start munin.service: Unit munin.service is masked.
make from source fails with
Can't locate MasterBuilder.pm in @INC (you may need to install the MasterBuilder module) (@INC contains: /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.24.1 /usr/local/share/perl/5.24.1 /usr/lib/arm-linux-gnueabihf/perl5/5.24 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.24 /usr/share/perl/5.24 /usr/local/lib/site_perl /usr/lib/arm-linux-gnueabihf/perl-base) at Build.PL line 1.
BEGIN failed--compilation aborted at Build.PL line 1.
Makefile:452: recipe for target 'master/Build' failed
make: *** [master/Build] Error 2
I'm using Raspbian Stretch Lite (2018-04-18). What can I do?
Aurora0001
  • 6,357
  • 25
  • 39
Marco
  • 131
This appears to be the same issue as bug #837788 in the Debian bug tracker. It appears that this is actually by design, and Munin installed without any problems from the repo on your Pi:
On Fri, 10 Mar 2017 at 07:46:17 +0100, Stig Sandbeck Mathisen wrote:
Munin needs /run/munin created with the correct permissions.
<p>When using sysv init, the /etc/init.d/munin script does that, and exits.</p>
Aha. So the boot process (systemd or sysvinit) in jessie and stretch is not meant to start munin at all, only prepare the necessary directory for it to be started by the web server?
If that's the case, then perhaps this bug could be closed as "working as intended", or downgraded to wishlist and retitled "systemctl restart munin does nothing".
If you are having trouble with Munin, it is likely not due to the "masked" message from systemd; this is intentional.
Aurora0001
  • 6,357
  • 25
  • 39
