I know how to set an static ip. I have 2 configured networks in wpa-supplicant. An i use to use the same static ip in both networks (2 different networks but same wifi range).
The problem is that my static ip is 10.92.x.x and my mobile network i in 192.168.x.x so is not possible to use that. What i want is that when i have that problem i can add a network in wpa_supplicant (My host is under windows 10 and from windows i can't access to /boot), that is the only folder that i can see from windows and then use the dhcp to get ip. Later on i will use ip scanner angry ip or even i will check my phone to check it the ip out.
The question is simple i want to have different networks with different static ips.
Thanks in advance
Ingo
  • 42,961
  • 207
