I would like to get Ubuntu Mate 16.04 on the Raspberry Pi 3 B+. According to this thread this should be possible. Here is the summary on how they achieved it:
Copy the following files from Raspbian to Ubuntu Mate:
  • For Booting: copy bootcode.bin, fixup.dat, start.elf, bcm2710-rpi-3-b-plus.dtb and kernel7.img
  • For keyboard/mouse: copy /lib/modules/4.9.80-v7+ (root partition)
  • For network: copy the contents of /lib/firmware/brcm/ (root partition)
If you want to boot from USB:
  • edit cmdline.txt, change root=/dev/mmcblk0p2 to root=/dev/sda2 (boot partition)
  • edit etc/fstab, change/dev/mmcblk0p2 to sda2 and /dev/mmcblk0p1 to sda1 (root partition)
My question is where to copy /lib/modules/-v7+ and /lib/firmware/brcm from the root partition. I was able to get raspian running on the raspberry pi 3B+ and then I copied the /lib/ files/folders to a usb stick. But I don't know where to put them on the sd card with ubuntu mate on it. I would copy them to the same location if I had ubuntu mate running on the pi already. However, I don't get this far.
Other steps I did so far:
  • mount raspian image
  • mount ubuntu mate image
  • copy files from the boot partition (bootcode.bin, fixup.dat, start.elf, bcm2710-rpi-3-b-plus.dtb and kernel7.img) of the mounted raspian image to the mounted ubuntu mate image.
I was then able to boot from this sd card to the point where I got the following error and could not type any commands:
Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details
But I don't know how to fix this error because I cannot enter any commands. The only thing that works is switching terminals using Ctrl+Alt+F1...
evolved
  • 99
It all depends on where you are starting; the Ubuntu MATE image is very old - 16.04.2 and there have been updates to 16.04.4, but you need a working image to perform the update.
Ubuntu MATE has not had a firmware/kernel update for some time (since Wimpy left?) and AFAIK none are planned; 18.04 should be available in July.
The Pi3B+ NEEDS new firmware/kernel to boot, but this is only a first step; ideally the OS needs to be tested for compatibility. (Ubuntu MATE is still using a 4.4 kernel, and 4.9 had significant changes - Raspbian in now using 4.14.)
You could try rpi-update (although this needs to be used with caution), OR copy raspberrypi-bootloader raspberrypi-kernel from a Raspbian site (I have not tried this), OR copy the new bootloader and kernels PLUS their modules from a Raspbian installation.
Updating is really a job for an expert Linux user.
